Virus In Latest 1.10.10 Release?
XrayDoc88
Post by XrayDoc88 » Sun Jan 21, 2018 10:57 pm
I was using the latest version of MakeMKV without incident the past few days. Now all of sudden Windows Defender is identifying the following as malicious and should be removed.
Trojan:Win32/Azden.A!c
If I remove this, I'm pretty sure MakeMKV doesn't work. Any advice?
Re: Virus In Latest 1.10.10 Release?
Post by Woodstock » Sun Jan 21, 2018 11:19 pm
virustotal.com says "0/66" hits for the file available at /download/ . The hash virustotal displays for the file tested matches that published for the Windows executable file.
Searching for "Win32/Azden.A!c" on google shows that Microsoft throws this judgement around quite a lot. No other antivirus product seems to detect a problem with the same files that Windows Defender quarantines, and "infections" seem to appear depending on when you installed Windows updates.
Ultimately, it's up to you to decide what to do. AVG (what I use) says the file is clean.
jasinswift
Post by jasinswift » Mon Jan 22, 2018 5:03 pm
I was checking yestarday MakeMKV.
Eversing fine.Comfirm it!
No virus,no trojans. :|
Dowload Kaspersky free and try check again file.Window Defender useless and give poor defense.
Because it does not handle the files as it should, and with any little inconsistency produces warnings.
I turned it off for a long time.
regards
jasin
_________________
The direct main step of bestazy.com My website in future.2018 hype! :D
XrayDoc88
Post by XrayDoc88 » Mon Jan 22, 2018 6:10 pm
Thanks Woodstock. Windows Defender was automatically quarantining the file and MakeMKV would stop working. I "restored" the quarantined file in Defender and now MakeMKV seems to be working ok.
