Subtitle suggestion
HakanL
Subtitle suggestion
Post by HakanL »
ripping subtitles in the PGS format works, but I can't find a way to extract the PGS tracks from the MKV file out to SUP files so I can process them into text files (OCR). My suggestion is that you add an option to extract them directly to SUP files. I realize it would be best if players could play PGS directly from MKV, but currently that's not very common, unfortunately.
Thanks for a great app!
/Hakan
Re: Subtitle suggestion
Post by mike admin »
Did you try to demux it with mkvmerge gui renaming the output file to SUP?
HakanL
Post by HakanL »
I'm looking at mkvmerge and it doesn't seem to have an option to demux. I also checked out mkvextract (and mkvextractgui) but the gui pops up a warning saying it can't extract these kind of tracks and mkvextract command line does the same thing. I can extract it as raw using mkvextract, but that doesn't seem to be a compatible SUP file, I tried to rename it but applications don't recognize it as a valid SUP file.
I found this posting as well: http://forum.videohelp.com/topic366584.html
