MakeMKV 1.10.10 AACS 64?
T'hain Esh Kelch
#1 Post by T'hain Esh Kelch » Sat Jan 20, 2018 1:17 pm
I just installed MakeMKV 1.10.10 and the changelog mentions support for AACS64, yet in the right side of MakeMKV under 'Drive information', I see "Highest AACS version: 63". Is this due to a drive limitation, a visual bug, or is the changelog incorrect? :)
Lovely Rita
Re: MakeMKV 1.10.10 AACS 64?
#2 Post by Lovely Rita » Sat Jan 20, 2018 1:57 pm
That will change once your drive "sees" a disc with AACS64. :wink:
For example, if you had never worked with a disc higher that AACS58, that would be reflected in your drive information.
Registered User :wink:
Buy MakeMKV
#3 Post by Woodstock » Sat Jan 20, 2018 4:43 pm
Actually, what I've figured out is that the "highest seen" is a result of AACS dump files found in your data directory.
Mine says it's seen AACS v63 because there's a file named MKB_v63_THREELEAVES_D1.tgz in my data directory. If I delete all of the MKB_vnn* files, MakeMKV won't know what the highest AACS version it has seen is, until I rip another BD... then THAT will be the "Highest AACS version:" value for a while.
T'hain Esh Kelch
#4 Post by T'hain Esh Kelch » Sat Jan 20, 2018 8:20 pm
Heh, that's funny. Thanks for the explanation guys. Turns out my 63 is Kong: Skull Island.
