remuxing UHD - HDR?
rugbyguy9
remuxing UHD - HDR?
#1 Post by rugbyguy9 » Fri Jan 19, 2018 6:01 am
is HDR being muxed with ripping UHD movies? does it show up as a 2nd video stream? what actually happens to the 10bit HDR?
thanks,
mbnwa
Re: remuxing UHD - HDR?
#2 Post by mbnwa » Fri Jan 19, 2018 9:10 pm
HDR works as expected as long as it's not Dolby Vision, it does not show up as a 2nd stream, as long as you have an HDR display / TV it should look exactly like the UHD at least in my case (excluding Dolby Vision)
preserve
#3 Post by preserve » Fri Jan 19, 2018 10:42 pm
The colorspace of the MKV will be a WCG colorspace. I guess the question is, what exactly is the HDR metadata, and where does that information get stored? Is there software that will show that metadata?
Using: ASUS BW-16D1HT 3.00
