is HDR being muxed with ripping UHD movies? does it show up as a 2nd video stream? what actually happens to the 10bit HDR?
thanks,
remuxing UHD - HDR?
mbnwa
Re: remuxing UHD - HDR?
HDR works as expected as long as it's not Dolby Vision, it does not show up as a 2nd stream, as long as you have an HDR display / TV it should look exactly like the UHD at least in my case (excluding Dolby Vision)
preserve
The colorspace of the MKV will be a WCG colorspace. I guess the question is, what exactly is the HDR metadata, and where does that information get stored? Is there software that will show that metadata?
Using: ASUS BW-16D1HT 3.00
