AACS V64 - host certificate is revoked by your drive
fcmiii
#1 Post by fcmiii » Wed Jan 17, 2018 10:48 pm
MakeMKV has suddenly stopped working for me as of yesterday. I inserted a new disc, and it was taking a while to read in MakeMKV. Then I noticed the new update, so I stoped the app and downloaded 1.10.9. After doing so, I spun up the disc again and this time I got a flurry of error messages (attached).
I then tried other discs that I had previously ripped and got the same error messages. I even tried reinstalling the older version of MakeMKV, but the problem persisted. I then attached my old BD drive and it worked with a second new disc that I was trying to rip, but when I reinserted the first disc, the problem happened again. I even tried the drives and the discs on my old computer and the problems persisted.
After reading some of the other forum posts, I've looked in my settings and found that the original disc is AACS v64 where as everything else is v63. I've clicked the link that it created to report the problem, but that seems to be all I can do. Make MKV (or any other ripping software I desperately tried) won't open ANY BDs played from either of my drives now (but will open DVDs).
So, ultimately, I have two questions...
1. Am I correct in assuming that v64 has locked my drives and there's nothing I can do until a new update is released?
2. Is there any idea how long it will take for the new update since 1.10.9 was just released?
Thanks for your help,
Frank
makemkv info.png (1.29 MiB) Viewed 59680 times
preserve
Re: AACS V64 - host certificate is revoked by your drive
#2 Post by preserve » Wed Jan 17, 2018 11:02 pm
If you haven't already, be sure to email the AACS dump file (MKB_v64_The_Night_Walker.tgz) to svq@makemkv.com - Mike will need that file.
Using: ASUS BW-16D1HT 3.00
mmmkv
#3 Post by mmmkv » Thu Jan 18, 2018 12:48 am
preserve wrote:Tip for everyone, MakeMKV displays the AACS version of the disc before you open the disc. Don't try to open the disc if the disc is higher than the current version that is supported by MakeMKV, which is v63.
By 'open' do you mean performing any actions besides having the drive idle after opening MakeMKV? Wanting to be sure how to detect and avoid such instances myself.
preserve
#4 Post by preserve » Thu Jan 18, 2018 1:04 am
Removed incorrect information.
mmmkv
#5 Post by mmmkv » Fri Jan 19, 2018 1:14 am
preserve wrote:<edited out original quote>
Just for those who may come across this, asked the dev for clarification and it turns out this is incorrect. Apparently it processes the certificate revocation or whathaveyou the moment you insert the disc in the drive, rather than after clicking Open in MakeMKV.
preserve
#6 Post by preserve » Fri Jan 19, 2018 2:15 am
mmmkv wrote:Just for those who may come across this, asked the dev for clarification and it turns out this is incorrect. Apparently it processes the certificate revocation or whathaveyou the moment you insert the disc in the drive, rather than after clicking Open in MakeMKV.
Removed incorrect info. Feel free to edit it out of your reply as well.
So did the dev give any further information that fcmiii asked for, such as what can be done about it?
mmmkv
#7 Post by mmmkv » Fri Jan 19, 2018 2:42 am
preserve wrote:So did the dev give any further information that fcmiii asked for, such as what can be done about it?
The question the dev responded to was just whether the steps mentioned in your post were accurate or not, but looks like v1.10.10 of MakeMKV was just released with AACS v64 support, so the OP is probably okay now I'd guess.
I suppose the takeaway is just to wait for updates before trying the latest Blu-Ray releases.
fcmiii
#8 Post by fcmiii » Fri Jan 19, 2018 2:47 am
Thanks for the heads up that the new version is available!
Everything opened perfectly this time!
cyborg
#9 Post by cyborg » Wed Oct 31, 2018 4:49 pm
I have the very same problem. I opened "Marrowbone" bluray, which is AACS v66 according to MakeMKV.
Now I am not able to open any bluray at all, I always get "Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive. The volume key is unknown for this disc - video can't be decrypted" for all discs.
So all I can do is wait for new MakeMKV version, right?
#10 Post by Woodstock » Wed Oct 31, 2018 6:33 pm
For right now, yes.
Did you forward the MKB file that was generated when you tried to open Marrowbone to svq@makemkv.com for Mike to analyze?
iMactouch
#11 Post by iMactouch » Fri Nov 02, 2018 3:30 am
Since yesterday I have the same problem here!
I can not open any Bluray any more. That is really sad!
#12 Post by Woodstock » Fri Nov 02, 2018 2:34 pm
Check your MakeMKV data directory for a file name that starts with "MKB_v66" and send that to svq@makemkv.com for analysis.
cyborg
#13 Post by cyborg » Fri Nov 02, 2018 2:43 pm
I did that already...
iMactouch
#14 Post by iMactouch » Fri Nov 02, 2018 5:16 pm
I did it also!
#15 Post by d00zah » Tue Nov 06, 2018 10:27 pm
MakeMKV v1.14.0 released. Should fix the cert revocation problem.
