1.10.9 not working with command line - crashes
ihopnavajo
I have a script that uses the command line interface (makemkvcon?--I forget what it's called) and with the 1.10.9 update, Makemkv keeps crashing. It reads the discs and pulls the info but then crashes. Is there an official place to report bugs like this?
Re: 1.10.9 not working with command line - crashes
This is as official as it gets, but the fastest way is to send the information to support@makemkv.com for Mike to see it.
Do you normally do debug logging? Are you directing the output from makemkvcon to a file for later review? Mike would need the log information.
