Unable to Use keys_hashed.txt File. What Am I Doing Wrong?
Re: Unable to Use keys_hashed.txt File. What Am I Doing Wron
#16 Post by mike admin » Mon Jan 15, 2018 10:36 pm
ekpen49 wrote: I have makemkv for Windows and Ubuntu 17.10.
John Wick with version 1.10.9, failed to rip under Ubuntu, same with Expendables 3 uhd, and Now you see me uhd, but ripped under Windows.
Is it still the case? Did you check the data dir location on Ubuntu? Any errors in log? This should work.
BigPines
#17 Post by BigPines » Tue Jan 16, 2018 5:20 pm
I can confirm there is a problem with the Mac version (on my Mac anyway). I tired to rip 0x8C1197288A6A299A394FE48DD239320958D96E68 HUNTSMAN_2 using the 01/15/2018 version of keys_hashed.txt but I get:
MakeMKV v1.10.8 darwin(x64-release) started
Debug logging enabled, log will be saved as xxxxxxxxxxxxxxxxxx/MakeMKV_log.txt
Optical drive "BD-RE HL-DT-ST BD-RE WH16NS40 1.02" opened in DASPI v1.5 mode.
The new version 1.10.9 is available for download at http://www.makemkv.com/download/
Using Java runtime from /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/bin/java
Saved AACS dump file as xxxxxxxxxxxxxxxxxx/.MakeMKV/MKB20_v60_The_Huntsman_Winter's_War.tgz
DEBUG: Code 0 at 8cs-r5\[xMQ,|Y9$:29396046
DEBUG: Code 0 at 8cs-r5\[xMQ,|Y9$:213134009
However, when I try the same disc with the same keys_hashed.txt in Windows, it works fine.
Mike, please let me know what other information I can provide to help you find and fix the problem.
Contents of the log file:
Debug log started at Tue Jan 16 17:16:54 2018 , written by MakeMKV v1.10.8 darwin(x64-release)
001005:0000 MakeMKV v1.10.8 darwin(x64-release) started
001004:0000 Debug logging enabled, log will be saved as xxxxxxxxxxxxxxxxxx/MakeMKV_log.txt
002014:0000 Optical drive "BD-RE HL-DT-ST BD-RE  WH16NS40 1.02" opened in DASPI v1.5 mode.
005075:0000 The new version 1.10.9 is available for download at http://www.makemkv.com/download/
Found java version=1.7.0 path=/Library/Java/JavaVirtualMachines/jdk1.7.0_79.jdk/Contents/Home/bin/java
Found java version=1.6.0.65 path=/System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home/bin/java
Found java version=1.8.0.74 path=/Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/bin/java
003344:0000 Using Java runtime from /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/bin/java
DEBUG: Code 2147483648 at -AW:YWGuw/wM=5-3:29396529
DAFD=PAAAADAAAAEABDQkEFwECAQ==
DCE=cWRp+jVm1jdDhcdYhIzCNL85w0xbyyCCkxUc67T8NAd/jh6xKsnJKeJYNh62XbVn6OR66LsO45EQ8vVy2DIgWKMTsjsMPAEANBI1rja0qcF0BidvdfEYau2DgaRop9O9aU5QMujmm5/4i7a4MX8D2YleWTk7LwXdWg==
DCE=MCB0/GFKAIRimKzBpVHB9cZTIlP60ooN4/6igne1RBN/c1eMfrKp0f4CgpUqzG4K0pSqojrpIcCtdBtdT7aTZAnGZ0MCHM6fkTepIOGJXcHcbTh3NIQnzmwQ3d8iKuiaIo8bPZ5EsA/wFKYWeyQlZS6rdLQsPl3A8g==
003332:0000 Saved AACS dump file as xxxxxxxxxxxxxxxxxx/.MakeMKV/MKB20_v60_The_Huntsman_Winter's_War.tgz
003303:0000 The volume key is unknown for this disc - video can't be decrypted
001003:0020 DEBUG: Code 0 at 8cs-r5\[xMQ,|Y9$:29396046
001003:0020 DEBUG: Code 0 at 8cs-r5\[xMQ,|Y9$:213134009
#18 Post by mike admin » Tue Jan 16, 2018 8:11 pm
BigPines wrote:I can confirm there is a problem with the Mac version (on my Mac anyway). I tired to rip 0x8C1197288A6A299A394FE48DD239320958D96E68 HUNTSMAN_2 using the 01/15/2018 version of keys_hashed.txt but I get:
You did read that hashed keys work from version 1.10.9, right?
BigPines
#19 Post by BigPines » Tue Jan 16, 2018 8:38 pm
Well that is embarrassing. Yes, I DID read that and I THOUGHT that was the version I was running on my Mac. Oops. After installing 1.10.9 on my Mac, it works just fine. THAT is what I was doing wrong. :oops:
Thank you for your help.
nicholfd
#20 Post by nicholfd » Wed Jan 17, 2018 12:00 am
I use a Mac. I just downloaded the file (Last edit: 16.01.2018) and am successfully ripping the US version of 4K UHD Deadpool.
I have 5 x other discs to rip when this finishes. So far, so good.
BTW - I'm using an LG WH16NS40 v1.02 drive. It seems to be working... I'll reply when finished.
UPDATE - the Deadpool rip worked, and the file played back ok using Kodi - WOOT!
ekpen49
#21 Post by ekpen49 » Wed Jan 17, 2018 11:41 am
Greetings:
Yes please. I tried ripping each uhd twice, then decided to try Windows. All three ripped ok.
I have not played them yet.
I sent you a few dumps last night.
My earlier dumps to you have John Wick, and the other two uhds.
Thanks.
George.
Badnews
For Oppo Users 203/205 Model
#22 Post by Badnews » Wed Jan 17, 2018 4:25 pm
Rip UHD to folder if you have the new Oppo 203/205 AND change the flag to AVCHD in folder. You can play the original movie. To defeat a Cinavia infected UHD with the Oppo/203/205 just make a UHD MKV then not detected.
This is thru the USB 3.0 port on the back of the Oppo's. Get yourself a 6TB HDD and enjoy. You can remove the Cinavia in UHD from the folder but the process will leave most clueless. So MKV Cinavia is bypassed. And NOOO the Oppo 203/205 doesn't play ISO....Jailbreak is junk.
Beats computer play... I don't know about other UHD players but if they accept AVCHD play and folder play then changing the flag in folder to AVCHD may work for you also. You can always change the flag back. It's only a byte.
The Oppo drive will not and never will play BDXL discs, So don't bother
thrang
#23 Post by thrang » Sun Jan 21, 2018 3:05 am
Just downloaded 1.10.10 on OS X, and installed the current key file in the . MakeMKV directory - using an LG BE16NU50 drive (firmware 1.01, as from factory)
When I put The Martian (extended edition) I get this:
MakeMKV v1.10.10 darwin(x64-release) started
Optical drive "BD-RE ASUS BW-12D1S-U E401d" opened in OS access mode.
Optical drive "BD-RE HL-DT-ST BD-RE BE16NU50 1.01d" opened in OS access mode.
Saved AACS dump file as /Users/xxxxxx/.MakeMKV/MKB20_v60_The_Martian_-_Extended_Edition_80F7.tgz
MakeMKV is registered, and setup appears to be correct...something obvious I'm missing?
thrang
#24 Post by thrang » Sun Jan 21, 2018 3:21 am
For comparison, I just installed under Windows, and using the same key hash, disc, and drive, I do not get the above error and it works.
nicholfd
#25 Post by nicholfd » Sun Jan 21, 2018 8:13 pm
thrang wrote:Just downloaded 1.10.10 on OS X, and installed the current key file in the . MakeMKV directory
What directory? On macOS, did you confirm the MakeMKV data directory:
Open MakeMKV -> MakeMKV Menu -> Preferences -> General -> MakeMKV data directory. THAT is where you must place the hash list file.
A.Fenderson
Re: For Oppo Users 203/205 Model
#26 Post by A.Fenderson » Tue Jan 23, 2018 5:46 pm
Sorry to be a bit off-topic, but...
Badnews wrote:The Oppo drive will not and never will play BDXL discs, So don't bother
I can't keep up with the relevant AVS owner's thread: was it stated by OPPO directly that they cannot or will not add support?
thrangster
#27 Post by thrangster » Wed Jan 24, 2018 11:35 pm
Yes, the default .MakeMKV directory, which is what is the path in Make MKV. Bizarre....
