Crashes right after "indexing"
fillynl
Post by fillynl » Tue Jan 16, 2018 7:16 pm
Basically, for every disc I tried this on the program crashes with a fatal error after indexing the disc. It seems to spike in CPU use, then just gives up. I have found no log, nor entries in Event Viewer. I'm on Win10x64. What could be causing this behaviour? Thanks,
Re: Crashes right after "indexing"
Post by Woodstock » Tue Jan 16, 2018 9:03 pm
Do you have debug logging turned on? MakeMKV will tell you the path of the log when you start it, if you do.
And no, not sure what to make of what you've said is happening.
fillynl
Post by fillynl » Sat Jan 20, 2018 12:54 pm
Updated to 1.10.10 still the same issue. But: debug log now works:
Debug log started at Sat Jan 20 12:49:31 2018 , written by MakeMKV v1.10.10 win(x64-release)
001005:0000 MakeMKV v1.10.10 win(x64-release) gestart
001004:0000 Debug logging is ingeschakeld, log wordt opgeslagen als C:\Users\Filip van Hoeckel/MakeMKV_log.txt
003007:0000 Gebruik maken van direct disc toegangsmode
003028:0000 Titel #1 was toegevoegd (7 cel(len), 1:19:44)
003028:0000 Titel #2 was toegevoegd (7 cel(len), 1:17:50)
003028:0000 Titel #3 was toegevoegd (7 cel(len), 1:07:27)
003028:0000 Titel #4 was toegevoegd (7 cel(len), 1:19:15)
005011:0000 Bewerking succesvol afgerond
csf9 me=2 ma=0
csf7
Application exited at Sat Jan 20 12:52:20 2018
fillynl
Post by fillynl » Sat May 12, 2018 4:30 pm
Updated to 1.12.2; still the same issue.
