Copy Protection error on Lord of The Rings DVD
jpmagui
Post by jpmagui »
I have used MakeMKV successfully on other DVDs. On this disk I get the following errors:
Opening files on harddrive at D:/VIDEO_TS
Calculated BUP offset for VTS #1 does not match one in IFO header.
Title #1 was added (36 cell(s), 2:46:10)
Error 'OS error - Copy protection error - The read failed because the sector is encrypted' occurred while reading 'D:/VIDEO_TS/VTS_01_1.VOB' at offset '8192'
DEBUG: Code 3221226249 at i*xOXNB02\B"BbfA8j:121262969
DEBUG: Code 1 at g>VHL8l8n,c{h.#o:29394390
DEBUG: Code 0 at fO\Vk/e@,GEG4z3:121270973
DEBUG: Code 0 at 96&tYOz>@CK pg:213134883
DEBUG: Code 233 at YLGgcu3yDMd7B4qQhwp2Qo1D:0
Re: Copy Protection error on Lord of The Rings DVD
Are you running MakeMKV as an administrator or a regular user? The log indicates that Windows is getting in the way of the key exchange.
jpmagui
Post by jpmagui »
I am running as the administrator on Windows 10
Just noticed this:
What did you use to get the files onto the hard drive? Or is Windows mis-reporting that drive D: is a hard drive?
PRAGMA
Post by PRAGMA »
Sorry for necroposting, but since no possible tricks were posted I decided ill post one for anyone googling.
Some possible fixes:
- Run makemkv as admin
- Take out and put back in the DVD
- Close MakeMKV, open dvddecrypter (get from videohelp or dvddecrypter.org.uk only) and use it's feature to change the DVD drive's region to the same one as the DVD disc.
You only get 5 region changes with most drives, then you're "stuck" on that region. It is bad to change it unnecessarily, because MakeMKV can usually work around it. I have not had any disk that it couldn't work around, and I've had disks from regions 1, 2, and 3 through my drives.
