American Assassin - DVD
bunk3m
#1 Post by bunk3m » Wed Jan 03, 2018 11:43 pm
Using MakeMKV 1.10.8 Mac.
I can't figure out which is the right title as it doesn't correspond to what VLC Player is playing. VLC is playing Title 29 17 chapters (1:53:32).
MakeMKV log
Debug log started at Wed Jan  3 23:31:07 2018 , written by MakeMKV v1.10.8 darwin(x64-release)
001005:0000 MakeMKV v1.10.8 darwin(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/philip/MakeMKV_log.txt
002010:0000 Optical drive "DVD+R-DL HL-DT-ST DVDRW  GA32N KE06d" opened in OS access mode.
002010:0000 Optical drive "BD-RE TSSTcorp BDDVDW SE-506BB TS00d" opened in OS access mode.
003025:0000 Title #1 has length of 70 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #2 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #3 has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title skip vts=3 pgcn=1 hash=826012C9800423A4
003028:0000 Title #5 was added (2 cell(s), 0:04:29)
003028:0000 Title #9 was added (5 cell(s), 0:26:03)
003025:0000 Title #19 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #20 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #21 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #22 has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title skip vts=16 pgcn=2 hash=939A882596A57E56
003028:0000 Title #24 was added (20 cell(s), 1:53:14)
001003:0020 DEBUG: Code 10551302 at a8p@2$#7v1>jb^%~:29405752
001003:0020 DEBUG: Code 0 at a8p@2$#7v1>jb^%~:29406741
001003:0020 DEBUG: Code 0 at Q+<~;Ye{kbpO&txw&a:29394229
003035:0000 CellWalk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
003037:0000 Cells 1-1 were removed from title start
003038:0000 Cells 18-18 were removed from title end
003028:0000 Title #25 was added (16 cell(s), 1:51:25)
Title skip vts=19 pgcn=1 hash=0B72DDBF03A0306F
003019:0000 Cells 2-4 were skipped due to cell commands (structure protection?)
003028:0000 Title #27 was added (16 cell(s), 1:47:31)
003028:0000 Title #28 was added (16 cell(s), 1:51:25)
003028:0000 Title #29 was added (16 cell(s), 1:51:25)
Title skip vts=18 pgcn=2 hash=6BFB15E3E3C785D7
003027:0000 Title 1 in VTS 18 is equal to title 1 and was skipped
However the menu list of available Titles shows only ID5 2 chapters; ID9 5 chapters; ID24 16 chapters (1:53:14); ID25 16 chapters (1:51:25); ID27 16 chapters (1:47:31). None match the time from VLC player.
How do I figure out which title should be copied?
Krawk
Re: American Assassin - DVD
#2 Post by Krawk » Wed Jan 10, 2018 11:10 pm
This title uses Playlist Obfustication, which Lionsgate is notorious for and MakeMKV doesn't seem to support on dvd. Maybe generate a logfile and send it to Mike?
bunk3m
#3 Post by bunk3m » Thu Jan 11, 2018 1:39 am
Krawk wrote:This title uses Playlist Obfustication, which Lionsgate is notorious for and MakeMKV doesn't seem to support on dvd. Maybe generate a logfile and send it to Mike?
Thanks for your reply!
I figured out how to do it in the end but I couldn't use MakeMKV. I used vobcopy and used the title that VLC Player showed.
I'll see if I have the logfile still and if I do, I'll send in.
