Optical Drive not being found
JokerJim
#1 Post by JokerJim » Tue Jan 09, 2018 4:31 am
I have downloaded and updated my MakeMKV installation to the newest version - 1.10.9 - on my Ubuntu system. When I try to run it, it claims that it cannot find any valid optical drives. I tried reinstalling to make sure that I didn't miss any steps and got the same response. I downgraded back to 1.10.8 and the drive is found just fine.
It appears to only be an issue with 1.10.9.
My drive according to version 1.10.8 is a BDDVDRW UH12NS30.
I am running Ubuntu 14.04.5 LTS.
Any assistance that you can provide would be appreciated.
Djoss
Re: Optical Drive not being found
#2 Post by Djoss » Fri Jan 12, 2018 5:56 pm
Same issue for me. Optical drive no longer recognized in 1.10.9, while it was in 1.10.8...
troelsfr
#3 Post by troelsfr » Fri Jan 12, 2018 8:07 pm
I have this problem too:
Linux 3.16.0-4-amd64 #1 SMP Debian 3.16.36-1+deb8u2 (2016-10-19) x86_64 GNU/Linux
Is there a place I can download 1.10.8?
#4 Post by d00zah » Fri Jan 12, 2018 8:35 pm
/faq/item/15
redjoe22887
#5 Post by redjoe22887 » Sat Jan 13, 2018 3:17 am
I am having this issue also had to downgrade from 1.10.9 back to 1.10.8 details as follows
OS: Linux Mint Debian Edition
Disk Drive: ASUS SBC-06D1S-U USB Blu-ray read/DVD rw
$ cat /etc/issue
LMDE 2 Betsy \n \l
$ uname -a
Linux 3.16.0-4-amd64 #1 SMP Debian 3.16.7-ckt7-1 (2015-03-01) x86_64 GNU/Linux
$ lsscsi
[1:0:0:0]    cd/dvd  ASUS     SBC-06D1S-U      A301  /dev/sr0
JohnJasonJordan
#6 Post by JohnJasonJordan » Sat Jan 13, 2018 5:53 am
JokerJim wrote:I have downloaded and updated my MakeMKV installation to the newest version - 1.10.9 - on my Ubuntu system. When I try to run it, it claims that it cannot find any valid optical drives. I tried reinstalling to make sure that I didn't miss any steps and got the same response. I downgraded back to 1.10.8 and the drive is found just fine.
I also have Ubuntu 14.04.5 (actually Xubuntu) and have exactly the same problem. 1.10.8 was working fine, but it wouldn't rip and encode a Blu-ray (US release of The Tall Blond Man with One Black Shoe), so I thought I'd try the upgrade. Now it can't see either of my optical drives.
In an effort to rip and encode the disc I used ddrescue to make an ISO file and then tried to get MakeMKV to use it instead of the disc in the drive, but it failed with 'The volume key is unknown for this disc - video can't be decrypted.'
I paid for MakeMKV, but I am disappointed, I am disappointed that I won't be able to watch a movie that I paid for, but I am especially disappointed that 1.10.9 is still online as the latest version in spite of crippling bugs. Someone needs to pull it until there is a fix for this problem.
cmosier
#7 Post by cmosier » Sun Jan 14, 2018 4:47 am
Just wanted to report that I am also experiencing the same issue. Reverting to an older version worked.
Linux Mint 17.2 3.16.0-38-generic #52~14.04.1-Ubuntu SMP
beltrancd
#8 Post by beltrancd » Sun Jan 14, 2018 9:10 am
troelsfr wrote:I have this problem too:
http://www.makemkv.com/download/old/
beniwtv
#9 Post by beniwtv » Sun Jan 14, 2018 1:13 pm
Just wanted to report the same issue here.
1.10.8 works fine, 1.10.9 can't find my drive (it's an internal SATA drive)
JohnJasonJordan
#10 Post by JohnJasonJordan » Mon Jan 15, 2018 1:05 am
beniwtv wrote:Just wanted to report the same issue here.
Is your OS Debian based? I ask because everyone else here has a Debian based OS. I suspect that the problem doesn't arise from that, but it's worth noting. I might also add that whenever I use MakeMKV on a Blu-ray it says that writing will be delayed because of a bug in the kernel that it has to work around.
__ap0
#11 Post by __ap0 » Wed Jan 17, 2018 5:14 pm
I'm on Arch Linux and have the same issue.
Metallikahn
#12 Post by Metallikahn » Thu Jan 18, 2018 3:54 am
I'm using unRAID 6.3.5 and and makemkv via the docker by jlesage https://hub.docker.com/r/jlesage/makemkv/ and I'm having the same issues. I'd go back a version but the whole point is to get the new UHD hash key capability that's unavailable in the previous build.
Anyone found any workarounds yet?
SonicBlue
#13 Post by SonicBlue » Thu Jan 18, 2018 2:54 pm
I just registered here to say: I've got CentOS 6.9 Linux (RedHat based) here, compiled the OSS part with GCC 7.2.0, same problem. Ah, and it's x86_64. Tried to run it as a regular user and as root, no luck. makemkvcon also doesn't see any usable drives.
akshunj
#14 Post by akshunj » Fri Jan 19, 2018 2:47 am
For those using a PPA (I think there's only one out there), how are you going about rolling back to a working version? Been banging my head against the wall trying to figure it out. I have never been able to compile makemkv from source successfully, so I started using the PPA years ago. Any thoughts?
spl147
#15 Post by spl147 » Fri Jan 19, 2018 4:56 pm
has this been fixed in V.1.10.10?
