Segment map for Redbox blu ray Wish Upon?
jakehanl
Does anyone know which segment map is correct for the movie Wish Upon? It shows both 800.mpls and 801.mpls are both the main feature
Re: Segment map for Redbox blu ray Wish Upon?
Do you want English or Spanish?
Disney movies will have multiple versions (800, 801, sometimes 802 or 803) that differ only in the intended viewing language. As such, the opening and ending credits will be different, but the rest of the segment map will be the same.
800 is almost always the English version on Region A disks.
