Fatal error from successful disc backup and from disc.
Title: Nine Inch Nails Live: Beside You in Time (BR)
I have the last MakeMKV for Mac and the latest allcombo.svq. I have 2 different brand Blu-Ray drives. I get a Fatal error if I try to MakeMKV from either drive, but MakeMKV full disc Backup was successful, and I also get a Fatal error when I try to process the Backup to an MKV. Any ideas? Thanks!
Re: Fatal error from successful disc backup and from disc.
Wow I thought after a couple days I might have a reply...
- Contact:
The log shows that VC-1 video is encoded not in accordance with blu-ray spec. Is this a regular commercial blu-ray disc?
Yes, it is. Title: Nine Inch Nails Live: Beside You in Time (BR) - http://www.amazon.com/Nine-Inch-Nails-L ... 532&sr=8-1mike admin wrote:The log shows that VC-1 video is encoded not in accordance with blu-ray spec. Is this a regular commercial blu-ray disc?
- Contact:
Then it's a bug in MakeMKV. Your log contains all diagnostic information, there's nothing you can do right now for work around.
No problem, I was just looking to tell you about it Mike so it might get fixed one day. Thank you.
Hello there.
I have the same problem with the disc. at least the newer version of makeMKV recognizes the valid length of the main feature, 1:32:28 instead of 40 odd something minutes.
Saving 1 titles into directory /Volumes/Media/HD
DEBUG: Code 0 at K.d>/q.#5<psfdj?#.I:213131525
DEBUG: Code 0 at db(U'_iL&izym*Rbn#V*O:29397449
DEBUG: Code 0 at a+>Es62@;/*QoW6p@9h:121263751
DEBUG: Code 0 at a+>Es62@;/*QoW6p@9h:29399818
DEBUG: Code 0 at a+>Es62@;/*QoW6p@9h:121265200
DEBUG: Code 0 at a+>Es62@;/*QoW6p@9h:213130444
DEBUG: Code 0 at a+>Es62@;/*QoW6p@9h:121261934
DEBUG: Code 0 at db(U'_iL&izym*Rbn#V*O:121265775
DEBUG: Code 0 at RqKWk})Y!>)e2%(~bo,:29394160
DEBUG: Code 0 at RqKWk})Y!>)e2%(~bo,:29395195
Failed to save title 0 to file /Volumes/Media/HD/title00.mkv
0 titles saved, 1 failed
Devices: WDTV Live Hub, LG GGW-H20L, MacPro 1.1, and microsoft hd dvd drive with MBP 2011
Software: MakeMKV 1.7.4, OSX 10.7.3
- Contact:
Is it the same disc? The error indicates an invalid VC-1 interlaced stream, or another bug in MakeMKV.beatmaster wrote:Hello there.
yes, its the same disc as nathaniel7 mentioned. heck, its even the same place i bought it
still not working, new message though:
Saving 1 titles into directory /Users/xxx/Movies
DEBUG: Code 0 at 1)FjO]"Qy6H&!MBg]V0:213131525
DEBUG: Code 0 at luo#3Eb+D*r/#@J397H>s:29397449
DEBUG: Code 0 at c`3WolRZvs{N2#VuL-[:121263751
DEBUG: Code 0 at c`3WolRZvs{N2#VuL-[:121267822
DEBUG: Code 0 at c`3WolRZvs{N2#VuL-[:121265200
DEBUG: Code 0 at c`3WolRZvs{N2#VuL-[:213130444
DEBUG: Code 0 at c`3WolRZvs{N2#VuL-[:121261934
DEBUG: Code 0 at luo#3Eb+D*r/#@J397H>s:121265775
DEBUG: Code 0 at x\a?3*Imqm*~?QB+vvl:29394160
DEBUG: Code 0 at x\a?3*Imqm*~?QB+vvl:29395195
Failed to save title 0 to file /Users/xxx/Movies/title00.mkv
- Contact:
Your full debug log file should contain a lot of additional info. Please mail it to support@makemkv.com for troubleshooting, feel free to remove any private information from it.beatmaster wrote:still not working, new message though:
sadly it still doesn’t work with 1.6.10
i’ll send the debug log file again.
Did this ever get resolved? I have the same blu-ray and I get the same error when trying to MakeMKV.
had to make a decrypted backup with makemkv, and then use tsmuxerGUI and mkvtoolsnix to get a working mkv with chapters.
took me several attempts. trying with the new beta once I've got enough time to spare.
Not working in 1.7.77 (OS X). Immediate fail when trying to decrypt.
