UHD drives
ekpen49
Re: UHD drives
#46 Post by ekpen49 » Sat Dec 30, 2017 1:22 am
starmax wrote:Also tried it with my Ultra HD "official" drive, just to see if I could do an encrypted backup, got a similar but different error:
Error 'Scsi error - HARDWARE ERROR:LOGICAL UNIT HAS NOT SELF-CONFIGURED YET' occurred while reading '/BDMV/STREAM/00063.m2ts' at offset '21286090752'
DEBUG: Code 0 at qOI*=wx5:j{WPf8Pod3:213134354
DEBUG: Code 0 at qOI*=wx5:j{WPf8Pod3:29397564
DEBUG: Code 0 at <0W<vOVSs.X)9gR.Buo#:213133319
Backup failed
Product: BD-RE WH16NS60
Revision: 1.00
Serial number: SIK9RH8IB310
Firmware date: 2117-04-25 17:56:
Highest AACS version: 60
So, not sure what to try next. I don't have any other UHD discs...
Greetings:
I purchased same drive from Fry. Got cert. revoked and a couple of other similar messages. Mine came with the Power DVD software, which I did not install. In fact it behaved like the Pioneer uhd optical drive. I sent mine back for credit.
I am expecting Asus BW-16D1HT.
George
starmax
Re: UHD drives
#47 Post by starmax » Sun Dec 31, 2017 4:18 am
ekpen49 wrote: Greetings:
George
Got mine from Fry's too when they were on sale for $69. Saw they were recommended on the DeUHD site, so i went ahead, didn't realize getting a fully supported drive would end up being a negative :shock:
Ended up buying the Asus from Amazon while they were running the Dec $25 rebate, we'll see if Asus actually honors it. Mine came with 3.01 firmware, and the drive is dated May 2017 i believe.
mmmkv
Re: UHD drives
#48 Post by mmmkv » Mon Jan 01, 2018 9:09 am
Cross-posting in this topic since it may be more relevant:
mmmkv wrote:Does anyone know whether the BW-16D1HT-PRO (alternatively listed as BW-16D1HT PRO) model is equivalent in its UHD reading ability and firmware?
It appears to be a model made for the Australasia regions but can't find any info regarding the UHD aspect since all references in the UHD-related threads refer to the non-Pro model available elsewhere. Only reference I could vaguely source was one user who believes it's a re-badged LG BH16NS40.
Update: can confirm it's similarly UHD-friendly.
smartieyoung
Re: UHD drives
#49 Post by smartieyoung » Tue Jan 02, 2018 12:56 am
i can confirm I got my lg 16beu50 to work with UHD discs once i got the key sq right it worked like a charm.I was able to backup my copy of hacksaw ridge and reverent.still working on others but im glad i got a working drive.
eyeangle
Re: UHD drives
#50 Post by eyeangle » Wed Jan 03, 2018 3:02 am
Has anybody tested the Pioneer BDR-211UBK ?
I'm on macOS 10.13.2
As far as I know there is no UHD Blu-ray disc playing software for the mac. I've contacted macgo blu-ray player and they don't support it.
So I want to rip the UHD blu-rays using MakeMKV and then I can use Macgo blu-ray player to watch them.
Pheran
Re: UHD drives
#51 Post by Pheran » Wed Jan 03, 2018 5:35 am
eyeangle wrote:Has anybody tested the Pioneer BDR-211UBK ?
That drive has official UHD support, which means it almost certainly will not work for ripping.
ekpen49
Re: UHD drives
#52 Post by ekpen49 » Wed Jan 03, 2018 6:22 am
Yes,
Junk. I purchased mine last year. It is useless for uhd ripping, same with LGWH16NS60.
Both are bundled with power dvd crap.
George
eyeangle
Re: UHD drives
#53 Post by eyeangle » Wed Jan 03, 2018 6:26 am
ekpen49 wrote:Yes,
George
Thanks for your response, George. Out of curiosity does it rip normal blu-ray movies?
Also, what drive do you recommend to rip UHD and blu-ray movies?
ekpen49
Re: UHD drives
#54 Post by ekpen49 » Wed Jan 03, 2018 3:49 pm
eyeangle wrote:
ekpen49 wrote:Yes,
George
It rips normal blu ray.
Try the LG-WH16NS40. I have two working here. stay away from the LG WH16NS60
I am also expecting two Asus BW-16D1HT any day from now.
The Asus referenced above is known to work. I will update when I get mine.
George
starmax
Re: UHD drives
#55 Post by starmax » Fri Jan 05, 2018 10:45 pm
Well I bought a cheap copy of The Amazing Spider-man 2 from eBay since I was having issues with Deadpool. Ripped perfectly with my ASUS BW-16D1HT (firmware 3.01), so my Deadpool issue must be something with that movie/disc. Has anyone else experienced an issue where only 1/2 the movie rips properly? I bought the Deadpool disc a while ago just to test out UHD on my Xbox One S. Probably didn't watch more than 15 mins on my non-HDR 4k TV because UHD Blu-rays without HDR aren't really all that impressive, IMHO. Anyone know if its possible to get replacement discs from the manufacture? :lol:
Browneye9999
Re: UHD drives
#56 Post by Browneye9999 » Sat Jan 06, 2018 4:51 am
I have a LG BH16NS55 which was working with UHD discs okay on version 1.02 firmware.
I upgraded the firmware to 1.03 which according to LG allowed for 'better compatibility with UHD discs'.
Since the upgrade it won't recognise UHD discs at all now. Any one else seen this?
preserve
Re: UHD drives
#57 Post by preserve » Sat Jan 06, 2018 6:34 am
Browneye9999 wrote:I upgraded the firmware to 1.03 which according to LG allowed for 'better compatibility with UHD discs'. Since the upgrade it won't recognise UHD discs at all now.
FAQ thread and the first post of this thread both clearly state do not upgrade firmware.
My guess would be something along the lines that the firmware update may have changed your UHD-friendly drive into a drive that must follow all the official UHD requirements / protections, and as a result, your drive is no longer in the UHD-friendly category and software such as MakeMKV can no longer make use of your drive.
Read the first post of this thread for a fuller, better explanation.
Using: ASUS BW-16D1HT 3.00
Re: UHD drives
#58 Post by SamuriHL » Sat Jan 06, 2018 4:49 pm
That's exactly what 1.03 does. It removes the ability of the drive to read UHD discs at all. You'll have to search for it, but, there's a method to revert to 1.02. I will warn you that it's not simple or straightforward because they specifically patched it to not allow firmware downgrade. But there is at least 2 separate solutions out there for it.
Browneye9999
Re: UHD drives
#59 Post by Browneye9999 » Sun Jan 07, 2018 10:48 am
Ummm yeah, I'm an idiot. The drives aren't expensive, I'll just get another one.
ghost rider
Re: UHD drives
#60 Post by ghost rider » Sun Jan 07, 2018 4:43 pm
Browneye9999 wrote:Ummm yeah, I'm an idiot. The drives aren't expensive, I'll just get another one.
Just a word of caution the new LG drive may come with the 1.03 fw installed. You might think about a ASUS BW-16D1HT it is my understanding that the newest fw will not disable reading of UHD discs.
