Can't use activation code
ninjamads
#1 Post by ninjamads » Mon Jan 01, 2018 3:10 pm
Hi, just installed the latest 1.10.8 version on Linux. I use the program rarely but just now and then. Now its too old so I wanted to install the registration key. But I can't. I can't find info on what settings file to put the key-string into. When I open the GUI version I can't find any help menu that is mentioned as where to find the reg-dialog box.
Help! I want to register, but I can't. :)
Thx,
Mads
Re: Can't use activation code
#2 Post by Woodstock » Mon Jan 01, 2018 4:00 pm
I can't remember if the Linux GUI version has the same Help->Register menu item as the Windows and Mac versions, but that's where I'd look first. It should update the file that the CLI uses.
ninjamads
#3 Post by ninjamads » Tue Jan 02, 2018 9:15 am
yeah, it doesn't.
#4 Post by d00zah » Tue Jan 02, 2018 3:17 pm
It's from an old post & things may have changed, or there may be differences between 'nix distros, but I believe the fundamentals detailed:
'... key is working and located in ~/.MakeMKV/settings.conf
Looks like this :
app_Key = "<key_goes_here>"'
