"Starter for 10"
rayfun
"Starter for 10"
#1 Post by rayfun » Sun Dec 31, 2017 10:08 am
Trying to backup "Starter for 10"
https://www.amazon.de/Starter-10-Cather ... ter+for+10
Actual movie title is skipped:
"003015:0000 Title #5 (1:36:38) was skipped due to navigation error"
Compressed MakeMKV_log.txt is attached.
Best regards,
ray
Re: "Starter for 10"
#2 Post by Woodstock » Sun Dec 31, 2017 4:19 pm
I don't have anything that undoes 7z files, so I can't look at your log, but I'm sure Mike does.
For fastest response, send the log as the other files requested in the FAQ link in my signature to support@makemkv.com so that Mike sees it faster. In the short term, you may have to open the disk manually to force it to try ripping the main title, but navigation errors usually mean that the directory entry points to impossible places... which can happen if the disk is mastered in a weird way, or there are read errors loading the directory.
rayfun
#3 Post by rayfun » Mon Jan 01, 2018 9:41 pm
Woodstock wrote:I don't have anything that undoes 7z files, so I can't look at your log, but I'm sure Mike does.
Added as ZIP to original post.
Thanks,
ray
#4 Post by Woodstock » Mon Jan 01, 2018 10:10 pm
Well, I've never seen that many debug messages in a log. And Mike will have to be the one to decoded them, because MakeMKV tried tens of thousands of ways to work around something that was on that disk.
