Run Instances of MakeMkv Simultaneously
Mtenga
#1 Post by Mtenga » Mon Jan 01, 2018 10:00 am
I have an internal and external burner and would like to rip two discs at once to speed things up. Is this possible on Windows?
paulster
Re: Run Instances of MakeMkv Simultaneously
#2 Post by paulster » Mon Jan 01, 2018 10:38 am
Just launch MakeMKV twice. That's how I do it on Windows.
Mtenga
#3 Post by Mtenga » Mon Jan 01, 2018 12:56 pm
paulster wrote:Just launch MakeMKV twice. That's how I do it on Windows.
OK cheers I'll give it a go later this week. I thought that I'd read that wouldn't work but if it does then problem solved easily.
#4 Post by Woodstock » Mon Jan 01, 2018 3:58 pm
You first have to activate single-drive mode, as I explained in my reply to your other message.
In Windows, you either need to use the start menu to start a second (or third, or ...) instance, or you need to RIGHT click on the icon in the task bar, and select the top menu item (MakeMKV) to start a new instance.
