The Hobbit (Extended Edition)
arglebargle
#1 Post by arglebargle » Sun Dec 31, 2017 9:52 pm
I don't get it. I ripped this fine a couple months ago, but now I get an error:
MakeMKV v1.10.8 linux(x64-release) started
Debug logging enabled, log will be saved as /xxx/xxx/MakeMKV_log.txt
Internal error: openssl test 00FC failed
Evaluation version, 29 day(s) out of 30 remaining
DEBUG: Code 0 at ]Kfci6TS8!<BGWCl0]:213130789
Saved AACS dump file as /xxx/xxx/.MakeMKV/MKB_v42_The_Hobbit_An_Unexpected_Journey_Extended.tgz
DEBUG: Code 0 at 2T{ed7<\OGLUtF{r:29396046
DEBUG: Code 0 at 2T{ed7<\OGLUtF{r:213134009
Any thoughts?
Re: The Hobbit (Extended Edition)
#2 Post by Woodstock » Sun Dec 31, 2017 11:03 pm
MakeMKV is having an issue with OpenSSL, which is needed for decoding things. There are other reports about this library not being detected in the Linux forum - I haven't been paying attention to them, so I don't know what the fix is.
arglebargle
#3 Post by arglebargle » Sun Dec 31, 2017 11:10 pm
Ah, thanks, that gives me something to go on.
