The Hobbit (Extended Edition)
arglebargle
Post by arglebargle »
I don't get it. I ripped this fine a couple months ago, but now I get an error:
MakeMKV v1.10.8 linux(x64-release) started
Debug logging enabled, log will be saved as /xxx/xxx/MakeMKV_log.txt
Internal error: openssl test 00FC failed
Evaluation version, 29 day(s) out of 30 remaining
DEBUG: Code 0 at ]Kfci6TS8!<BGWCl0]:213130789
Saved AACS dump file as /xxx/xxx/.MakeMKV/MKB_v42_The_Hobbit_An_Unexpected_Journey_Extended.tgz
DEBUG: Code 0 at 2T{ed7<\OGLUtF{r:29396046
DEBUG: Code 0 at 2T{ed7<\OGLUtF{r:213134009
Any thoughts?
Re: The Hobbit (Extended Edition)
MakeMKV is having an issue with OpenSSL, which is needed for decoding things. There are other reports about this library not being detected in the Linux forum - I haven't been paying attention to them, so I don't know what the fix is.
arglebargle
Ah, thanks, that gives me something to go on.
