Naming MKV output
meyoda99
Naming MKV output
#1 Post by meyoda99 » Thu Apr 20, 2017 3:37 pm
As a new and registered user I cannot find a way to configure MKV so the output name is the same name of the movie/show as detected by MKV. In other words, the default name of the output MKV file is always "title00.mkv" and is not the name of the movie that I wish to convert.
Please advice...
NOTE: If this is not possible in the current version, can a feature be added so users have the ability to set the name of the output file?
Thanks.
Re: Naming MKV output
#2 Post by Woodstock » Thu Apr 20, 2017 7:10 pm
Preferences->General, make sure that "Expert mode" is checked. New options will appear on your screen.
When you open a disk, you can now edit what is present for the disk name. This affects the title names displayed. You will also be able to edit the individual title names, which will affect the file name.
And, if you look at the "Name" label "button", it is a "pull-down", where you can edit OTHER information about the title, including the file name.
Play around - there's more to it than I can explain in a short message, and it can do everything you want.
MSDowney
#3 Post by MSDowney » Tue Aug 22, 2017 8:08 pm
Woodstock wrote:Preferences->General, make sure that "Expert mode" is checked. New options will appear on your screen.
Is this only in the Registered (purchased) version? I am looking in the advanced window and all it has is
Default Profile
Default Selection Rule
dtsdecoderdll.dll locaton
There are not other options
Lovely Rita
#4 Post by Lovely Rita » Tue Aug 22, 2017 10:12 pm
You're looking up the wrong tree. :D
Woodstock wrote:Preferences->General, make sure that "Expert Mode" is checked.
Your Preference window may look different since I'm on a Mac. 8)
Registered User :wink:
Buy MakeMKV
indyjoe1977
#5 Post by indyjoe1977 » Tue Sep 12, 2017 4:47 pm
This was helpful for me, too! Thanks! :mrgreen:
elbandito1200
#6 Post by elbandito1200 » Fri Dec 29, 2017 6:25 pm
Gotta "hijack" this thread somehow concerning getting rid of this "_t00"-addition to the ripped filenames.
Often Makemkv ripped the files naming them "title0x" with x variing according to the track being ripped. I found, that you can change that to the name you want if you click the corresponding title in the list and then enter the name in the "Settings"-field after "Name". BUT: Makemkv still adds "_t0x" (x being the tracknumber obviously) to that name. How can I remove that?
Thx for any help!
Greetz
Elbandito1200
Edit: Never mind, I found it in the dropdown menu: filename - change the name there and it's getting ripped as you want it.
#7 Post by Woodstock » Fri Dec 29, 2017 9:08 pm
That was kind of why I put together the "Changing names with Expert mode enabled" topic in the General section. There are a lot of things hidden until you turn on Expert mode. And Expert mode itself is rather buried. :roll:
