Asus BW-16D1HT Firmware
PauleFoul
Re: Asus BW-16D1HT Firmware
#16 Post by PauleFoul » Mon Dec 25, 2017 7:36 pm
Badnews wrote: If you want to flash your drive from 3.01 to 3.00 this modified flasher and bin file will do it from link below
At the moment i see no reason to do this flashback...
https://www.makemkv.com/forum2/viewtopi ... 951#p58951
TeddyRaspin
#17 Post by TeddyRaspin » Thu Dec 28, 2017 1:56 pm
Hi.
Please someone with Asus firmware 3.01 could share a dump of the firmware ?
These are the steps.
You need Devilscraw flasher, which can be found here :
https://github.com/devilsclaw/flasher/releases
Then, open an elevated command prompt and type :
flasher -D (to display drive and drive ID)
and then
flasher -d [drive id] -l firmware.bin 6 00000000 00200000
and it should dump the current (3.0.1) firmware of your device.
Thanks in advance. :)
Pheran
#18 Post by Pheran » Sat Dec 30, 2017 7:06 pm
TeddyRaspin wrote:Hi.
Here you go, hope it's helpful.
firmware.7z
3.01 firmware compressed with 7zip
(1.14 MiB) Downloaded 2468 times
TeddyRaspin
#19 Post by TeddyRaspin » Sat Dec 30, 2017 10:03 pm
@Pheran
I will never thank you enough.
Thanks mate, it's the best gift after Christmas. :wink:
It increased the ripping speed (max 35 MB/s instead of 22.5) of UHD bluray discs !!!
mmmkv
#20 Post by mmmkv » Sun Dec 31, 2017 6:09 pm
Does anyone know whether the BW-16D1HT-PRO (alternatively listed as BW-16D1HT PRO) model is equivalent in its UHD reading ability and firmware?
It appears to be a model made for the Australasia regions but can't find any info regarding the UHD aspect since all references in the UHD-related threads refer to the non-Pro model available elsewhere. Only reference I could vaguely source was one user who believes it's a re-badged LG BH16NS40.
barrett70
#21 Post by barrett70 » Sun Dec 31, 2017 9:16 pm
@TeddyRaspin
what software did you use to flash your player?
TeddyRaspin
#22 Post by TeddyRaspin » Mon Jan 01, 2018 12:25 am
barrett70 wrote:@TeddyRaspin
DOSFlash
barrett70
#23 Post by barrett70 » Mon Jan 01, 2018 6:57 am
@TeddyRaspin
thank you for your answer, I never used this software how do you use it?
TeddyRaspin
#24 Post by TeddyRaspin » Mon Jan 01, 2018 8:45 am
I'm using a version modified by myself under pure dos and a USB stick,
but you can flash this firmware also under Windows using a LG unlocked flasher
and modify the .bin firmware (made with devilscraw flasher) with an hex editor.
Now I'm out for holidays, but I can make you a correct windows flasher together
with the 3.01 bin firmware suitable for any device having the MT1939 (MediaTek)
chipset (like almost LG and Asus recent bluray drives).
barrett70
#25 Post by barrett70 » Mon Jan 01, 2018 8:55 am
@TeddyRaspin
It would be nice of you if you could do it to me.
I do not know how to use this software.
Thanks.
KBJghost
#26 Post by KBJghost » Mon Jan 01, 2018 5:43 pm
TeddyRaspin wrote:I'm using a version modified by myself under pure dos and a USB stick,
I'd like to get that as well, if possible. Thanks!
TeddyRaspin
#27 Post by TeddyRaspin » Mon Jan 01, 2018 8:57 pm
Here we go. :D
ASUS_BW-16D1HT_3.01.zip
(2.96 MiB) Downloaded 3753 times
#28 Post by SamuriHL » Mon Jan 01, 2018 9:11 pm
TeddyRaspin wrote:Here we go. :D
Nice. Do you happen to have a 3.00 bin file that could be flashed with that modified flasher, as well? Thanks!
barrett70
#29 Post by barrett70 » Mon Jan 01, 2018 9:16 pm
Thanks For this great job!
happy New Year!
KBJghost
#30 Post by KBJghost » Mon Jan 01, 2018 9:20 pm
