dtsdecoderdll.dll
khuntim
dtsdecoderdll.dll
Post by khuntim »
I had an old copy of Arcsoft TotalMedia, installed it, registered and copied the dtsdecoderdll.dll (1.1.0.9) to the program files folder, set the path in the options and no audio at all in .mkv from blu-ray rip.
Thanks for any ideas
gereral1
Re: dtsdecoderdll.dll
Post by gereral1 »
https://www.youtube.com/watch?v=txaYjjEqa-0&t=11s
This version I use dtsdecode.DLL
Shows you how to get lpcm 7.1 from mkv files to enjoy dtshd or truehd.
khuntim
Post by khuntim »
I tried with the version you linked to: ( dtsdecoderdll.dll 1.1.0.1) and no go. no audio at all in MKV file. Blu-ray rip is fine.
strange, MakeMKV is supposed to have an open source DTS-HD decoder?
confused.
The open-source DTS decoder does not have all possible modes, as I understand it. Which is why there is still the option to use the closed-source one, if you can find it.
It's probably the same one used by handbrake, and they say it can't do 7.1.
khuntim
Post by khuntim »
I was able to get DTS-HD by selecting the exact track. may have just been my error. all is well.
