making a compatible key database file for use with make mkv
smartieyoung
Post by smartieyoung »
hi everyone im new here im just getting my feet wet with this uhd ripping with a friendly drive,im just curious though ive got the latest version of make mkv and i've downloaded the latest key db file from doom 9.I wanted to know do you past the whole keyfile db into the makemkv preference screen in the make mkv options screen or do you make a make a new folder in the make mkv folder and put this key db file into that folder.i hope i havent confused anyone ive just got several uhd discs that i want to try.i am very happy with makemkv and even if its not possible to rip 4k uhd files im perfectly happy with regular bluray ripping. thank you again mike for making such a program.
preserve
Re: making a compatible key database file for use with make
Post by preserve »
There are instructions on how to use MakeMKV with UHD discs and volume keys in a number of threads:
Official MakeMKV how-to: https://www.makemkv.com/faq/item/12
UHD support thread: http://makemkv.com/forum2/viewtopic.php?f=12&t=16765
UHD FAQ thread: http://makemkv.com/forum2/viewtopic.php?f=12&t=16883
Using: ASUS BW-16D1HT 3.00
