When trying to rip The Imitation Game It offers me quite a lot of MPLS files.
I tried my luck choosing one of them, the clips in the start of the movie was all scrabled randomly together.
With the 200 different versions I could rip, I chose to try out CloneBD, if found the correct MPLS without problems.
Is there something I can do to help MakeMKV find the correct MPLS? Is there something I can offer that will help the developers working with those problems in the future?
The Imitation Game (MPLS)
Re: The Imitation Game (MPLS)
Have you taken a look at this message in the general section?
http://makemkv.com/forum2/viewtopic.php?f=1&t=16791
It's title is "What is the correct play list [insert title here]?"
Yup, I have no such "log" as described, and I can't see anything special in my list to the left, and JRE is installedWoodstock wrote:Have you taken a look at this message in the general section?
Is there something specific I need to set up?
I'm running 1.10.8
If you do not have the "log window", you must be running the command line version. I cannot help with that. The graphic user interface has a portion of the window dedicated to logging what is going on, and the amount of detail shown is controlled by whether or not you have "debug logging" turned on. The FAQ link in my signature explains what that is and how to turn it on. As far as I know, the message about using the JRE appears in that part of the screen whether or not you have debugging turned on. It should also appear in the output of the makemkvcon.exe program, when you are using the CLI.
If you are not seeing any mention of the JRE, you probably do not have it installed, or it is installed in a non-standard location.
My computer chose to break, and now I have finally bought myself a new one.
Still, I have the same problem.
I know many posts are about this, but I can't seem to get the functionality for "Fake playlist" working.
Is there a guide for how you ensure that everything is set up properly?
Here is the log I guess you were talking about, it's in Danish, so be it:
I also tried setting the location of the Java.exe file manually, no luck.MakeMKV v1.10.10 win(x64-release) startede
Anvender direkte adgangsindstilling
Indlæst indhold af kontroltabel, forsøger at godkende integriteten af M2TS-filer.
Fil 00017.mpls blev tilføjet som titel #0
Fil 00018.mpls blev tilføjet som titel #1
Fil 00021.mpls blev tilføjet som titel #2
Fil 00025.mpls blev tilføjet som titel #3
Fil 00028.mpls blev tilføjet som titel #4
Fil 00030.mpls blev tilføjet som titel #5
Fil 00033.mpls blev tilføjet som titel #6
Fil 00035.mpls blev tilføjet som titel #7
Fil 00041.mpls blev tilføjet som titel #8
Fil 00045.mpls blev tilføjet som titel #9
Fil 00048.mpls blev tilføjet som titel #10
Fil 00049.mpls blev tilføjet som titel #11
Fil 00050.mpls blev tilføjet som titel #12
Fil 00055.mpls blev tilføjet som titel #13
Fil 00058.mpls blev tilføjet som titel #14
Fil 00074.mpls blev tilføjet som titel #15
Fil 00075.mpls blev tilføjet som titel #16
Fil 00076.mpls blev tilføjet som titel #17
Fil 00081.mpls blev tilføjet som titel #18
Fil 00082.mpls blev tilføjet som titel #19
Fil 00086.mpls blev tilføjet som titel #20
Fil 00091.mpls blev tilføjet som titel #21
Fil 00093.mpls blev tilføjet som titel #22
Fil 00096.mpls blev tilføjet som titel #23
Fil 00101.mpls blev tilføjet som titel #24
Fil 00107.mpls blev tilføjet som titel #25
Fil 00108.mpls blev tilføjet som titel #26
Fil 00121.mpls blev tilføjet som titel #27
Fil 00122.mpls blev tilføjet som titel #28
Fil 00129.mpls blev tilføjet som titel #29
Fil 00132.mpls blev tilføjet som titel #30
Fil 00134.mpls blev tilføjet som titel #31
Fil 00140.mpls blev tilføjet som titel #32
Fil 00142.mpls blev tilføjet som titel #33
Fil 00148.mpls blev tilføjet som titel #34
Fil 00155.mpls blev tilføjet som titel #35
Fil 00164.mpls blev tilføjet som titel #36
Fil 00166.mpls blev tilføjet som titel #37
Fil 00174.mpls blev tilføjet som titel #38
Fil 00180.mpls blev tilføjet som titel #39
Fil 00188.mpls blev tilføjet som titel #40
Fil 00189.mpls blev tilføjet som titel #41
Fil 00204.mpls blev tilføjet som titel #42
Fil 00207.mpls blev tilføjet som titel #43
Fil 00215.mpls blev tilføjet som titel #44
Fil 00216.mpls blev tilføjet som titel #45
Fil 00217.mpls blev tilføjet som titel #46
Fil 00220.mpls blev tilføjet som titel #47
Fil 00226.mpls blev tilføjet som titel #48
Fil 00231.mpls blev tilføjet som titel #49
Fil 00232.mpls blev tilføjet som titel #50
Fil 00236.mpls blev tilføjet som titel #51
Fil 00242.mpls blev tilføjet som titel #52
Fil 00243.mpls blev tilføjet som titel #53
Fil 00245.mpls blev tilføjet som titel #54
Fil 00254.mpls blev tilføjet som titel #55
Fil 00256.mpls blev tilføjet som titel #56
Fil 00258.mpls blev tilføjet som titel #57
Fil 00263.mpls blev tilføjet som titel #58
Fil 00267.mpls blev tilføjet som titel #59
Fil 00269.mpls blev tilføjet som titel #60
Fil 00270.mpls blev tilføjet som titel #61
Fil 00271.mpls blev tilføjet som titel #62
Fil 00286.mpls blev tilføjet som titel #63
Fil 00297.mpls blev tilføjet som titel #64
Fil 00302.mpls blev tilføjet som titel #65
Fil 00303.mpls blev tilføjet som titel #66
Fil 00304.mpls blev tilføjet som titel #67
Fil 00310.mpls blev tilføjet som titel #68
Fil 00317.mpls blev tilføjet som titel #69
Fil 00320.mpls blev tilføjet som titel #70
Fil 00325.mpls blev tilføjet som titel #71
Fil 00331.mpls blev tilføjet som titel #72
Fil 00332.mpls blev tilføjet som titel #73
Fil 00333.mpls blev tilføjet som titel #74
Fil 00339.mpls blev tilføjet som titel #75
Fil 00341.mpls blev tilføjet som titel #76
Fil 00344.mpls blev tilføjet som titel #77
Fil 00345.mpls blev tilføjet som titel #78
Fil 00350.mpls blev tilføjet som titel #79
Fil 00351.mpls blev tilføjet som titel #80
Fil 00359.mpls blev tilføjet som titel #81
Fil 00366.mpls blev tilføjet som titel #82
Fil 00370.mpls blev tilføjet som titel #83
Fil 00397.mpls blev tilføjet som titel #84
Fil 00398.mpls blev tilføjet som titel #85
Fil 00405.mpls blev tilføjet som titel #86
Fil 00409.mpls blev tilføjet som titel #87
Fil 00412.mpls blev tilføjet som titel #88
Fil 00414.mpls blev tilføjet som titel #89
Fil 00415.mpls blev tilføjet som titel #90
Fil 00416.mpls blev tilføjet som titel #91
Fil 00425.mpls blev tilføjet som titel #92
Fil 00431.mpls blev tilføjet som titel #93
Fil 00437.mpls blev tilføjet som titel #94
Fil 00459.mpls blev tilføjet som titel #95
Fil 00463.mpls blev tilføjet som titel #96
Fil 00476.mpls blev tilføjet som titel #97
Fil 00481.mpls blev tilføjet som titel #98
Fil 00483.mpls blev tilføjet som titel #99
Fil 00487.mpls blev tilføjet som titel #100
Fil 00494.mpls blev tilføjet som titel #101
Fil 00495.mpls blev tilføjet som titel #102
Fil 00504.mpls blev tilføjet som titel #103
Fil 00505.mpls blev tilføjet som titel #104
Fil 00507.mpls blev tilføjet som titel #105
Fil 00509.mpls blev tilføjet som titel #106
Fil 00524.mpls blev tilføjet som titel #107
Fil 00525.mpls blev tilføjet som titel #108
Fil 00526.mpls blev tilføjet som titel #109
Fil 00538.mpls blev tilføjet som titel #110
Fil 00542.mpls blev tilføjet som titel #111
Fil 00543.mpls blev tilføjet som titel #112
Fil 00545.mpls blev tilføjet som titel #113
Fil 00548.mpls blev tilføjet som titel #114
Fil 00557.mpls blev tilføjet som titel #115
Fil 00558.mpls blev tilføjet som titel #116
Fil 00565.mpls blev tilføjet som titel #117
Fil 00568.mpls blev tilføjet som titel #118
Fil 00573.mpls blev tilføjet som titel #119
Fil 00578.mpls blev tilføjet som titel #120
Fil 00588.mpls blev tilføjet som titel #121
Fil 00592.mpls blev tilføjet som titel #122
Fil 00598.mpls blev tilføjet som titel #123
Fil 00601.mpls blev tilføjet som titel #124
Fil 00602.mpls blev tilføjet som titel #125
Fil 00603.mpls blev tilføjet som titel #126
Fil 00606.mpls blev tilføjet som titel #127
Fil 00615.mpls blev tilføjet som titel #128
Fil 00621.mpls blev tilføjet som titel #129
Fil 00626.mpls blev tilføjet som titel #130
Fil 00632.mpls blev tilføjet som titel #131
Fil 00639.mpls blev tilføjet som titel #132
Fil 00641.mpls blev tilføjet som titel #133
Fil 00642.mpls blev tilføjet som titel #134
Fil 00648.mpls blev tilføjet som titel #135
Fil 00660.mpls blev tilføjet som titel #136
Fil 00664.mpls blev tilføjet som titel #137
Fil 00668.mpls blev tilføjet som titel #138
Fil 00683.mpls blev tilføjet som titel #139
Fil 00690.mpls blev tilføjet som titel #140
Fil 00692.mpls blev tilføjet som titel #141
Fil 00700.mpls blev tilføjet som titel #142
Fil 00704.mpls blev tilføjet som titel #143
Fil 00706.mpls blev tilføjet som titel #144
Fil 00714.mpls blev tilføjet som titel #145
Fil 00716.mpls blev tilføjet som titel #146
Fil 00718.mpls blev tilføjet som titel #147
Fil 00722.mpls blev tilføjet som titel #148
Fil 00732.mpls blev tilføjet som titel #149
Fil 00733.mpls blev tilføjet som titel #150
Fil 00735.mpls blev tilføjet som titel #151
Fil 00743.mpls blev tilføjet som titel #152
Fil 00746.mpls blev tilføjet som titel #153
Fil 00754.mpls blev tilføjet som titel #154
Fil 00756.mpls blev tilføjet som titel #155
Fil 00764.mpls blev tilføjet som titel #156
Fil 00767.mpls blev tilføjet som titel #157
Fil 00773.mpls blev tilføjet som titel #158
Fil 00783.mpls blev tilføjet som titel #159
Fil 00807.mpls blev tilføjet som titel #160
Fil 00808.mpls blev tilføjet som titel #161
Fil 00809.mpls blev tilføjet som titel #162
Fil 00811.mpls blev tilføjet som titel #163
Fil 00813.mpls blev tilføjet som titel #164
Fil 00814.mpls blev tilføjet som titel #165
Fil 00817.mpls blev tilføjet som titel #166
Fil 00818.mpls blev tilføjet som titel #167
Fil 00851.mpls blev tilføjet som titel #168
Fil 00863.mpls blev tilføjet som titel #169
Fil 00868.mpls blev tilføjet som titel #170
Fil 00869.mpls blev tilføjet som titel #171
Fil 00873.mpls blev tilføjet som titel #172
Fil 00879.mpls blev tilføjet som titel #173
Fil 00883.mpls blev tilføjet som titel #174
Fil 00886.mpls blev tilføjet som titel #175
Fil 00891.mpls blev tilføjet som titel #176
Fil 00901.mpls blev tilføjet som titel #177
Fil 00905.mpls blev tilføjet som titel #178
Fil 00911.mpls blev tilføjet som titel #179
Fil 00912.mpls blev tilføjet som titel #180
Fil 00920.mpls blev tilføjet som titel #181
Fil 00924.mpls blev tilføjet som titel #182
Fil 00927.mpls blev tilføjet som titel #183
Fil 00928.mpls blev tilføjet som titel #184
Fil 00929.mpls blev tilføjet som titel #185
Fil 00934.mpls blev tilføjet som titel #186
Fil 00935.mpls blev tilføjet som titel #187
Fil 00939.mpls blev tilføjet som titel #188
Fil 00941.mpls blev tilføjet som titel #189
Fil 00942.mpls blev tilføjet som titel #190
Fil 00946.mpls blev tilføjet som titel #191
Fil 00949.mpls blev tilføjet som titel #192
Fil 00951.mpls blev tilføjet som titel #193
Fil 00953.mpls blev tilføjet som titel #194
Fil 00957.mpls blev tilføjet som titel #195
Fil 00960.mpls blev tilføjet som titel #196
Fil 00966.mpls blev tilføjet som titel #197
Fil 00977.mpls blev tilføjet som titel #198
Fil 00985.mpls blev tilføjet som titel #199
Fil 00990.mpls blev tilføjet som titel #200
Fil 00992.mpls blev tilføjet som titel #201
Titel #00001.m2ts har en længde på 0 sekunder, som er mindre end minimums titellængden på 600 sekunder og springes derfor over
Titel #00004.m2ts har en længde på 0 sekunder, som er mindre end minimums titellængden på 600 sekunder og springes derfor over
Titel #00007.m2ts har en længde på 13 sekunder, som er mindre end minimums titellængden på 600 sekunder og springes derfor over
Titel #00008.m2ts har en længde på 0 sekunder, som er mindre end minimums titellængden på 600 sekunder og springes derfor over
Titel #00009.m2ts har en længde på 50 sekunder, som er mindre end minimums titellængden på 600 sekunder og springes derfor over
Titel #00010.m2ts har en længde på 10 sekunder, som er mindre end minimums titellængden på 600 sekunder og springes derfor over
Titel #00011.m2ts har en længde på 10 sekunder, som er mindre end minimums titellængden på 600 sekunder og springes derfor over
Titel #00012.m2ts har en længde på 10 sekunder, som er mindre end minimums titellængden på 600 sekunder og springes derfor over
Titel #00013.m2ts har en længde på 10 sekunder, som er mindre end minimums titellængden på 600 sekunder og springes derfor over
Titel #00020.m2ts har en længde på 30 sekunder, som er mindre end minimums titellængden på 600 sekunder og springes derfor over
Titel #00104.m2ts har en længde på 60 sekunder, som er mindre end minimums titellængden på 600 sekunder og springes derfor over
Titel #00109.m2ts har en længde på 0 sekunder, som er mindre end minimums titellængden på 600 sekunder og springes derfor over
Titel #01998.m2ts har en længde på 0 sekunder, som er mindre end minimums titellængden på 600 sekunder og springes derfor over
Handlingen udført
- Udklip.PNG (2.96 KiB) Viewed 9490 times
