Failed to open
Gkohler
Failed to open
Post by Gkohler »
MakeMKV v1.10.8 darwin(x64-release) started
Optical drive "BD-RE TSSTcorp BDDVDW SE-506AB TS01d" opened in OS access mode.
Calculated BUP offset for VTS #0 does not match one in IFO header.
Calculated BUP offset for VTS #2 does not match one in IFO header.
Title #1 with special attributes was skipped
Title #2 with special attributes was skipped
Title #3 with special attributes was skipped
Re: Failed to open
Right now MakeMKV is not working with "screener" disks. Follow the procedures in the FAQ link in my signature to send information to support@makemkv.com to see if Mike can work around it.
duffgardens
Re: Failed to open
Post by duffgardens »
i've been able to do battle of the sexes, hostiles, murder on the orient express, meyerowitz stories, the post, shape of water, coco and 3 billboards
i've had trouble with darkest hour, thor ragnarok, blade runner 2049
other folks have had success where i have failed though, so your mileage may vary
Gkohler
Re: Failed to open
Post by Gkohler »
I’m only having problems with Thor Ragnarak and The Last Jedi. Hoping a fix comes soon!
