true detective
tim909
true detective
Post by tim909 » Tue Dec 19, 2017 8:35 am
Redbox version of True Detective season 2. Double sided disc, each with 4 episodes.
First side worked fine. 2nd side keeps throwing errors, even with other programs. Surface looks flawless.
I was able to get 2/4 to complete.
AV sync issue in stream 0 at 1:11:46.001 : video frame timecode differs by +517.884s
AV sync issue in stream 0 at 1:11:46.585 : video frame timecode differs by +517.884s
AV sync issue in stream 0 at 1:11:52.508 : video frame timecode differs by +517.884s
AV sync issue in stream 0 at 1:11:53.425 : video frame timecode differs by +517.884s
AV sync issue in stream 0 at 1:11:57.846 : video frame timecode differs by +517.884s
AV sync issue in stream 0 at 1:12:01.266 : video frame timecode differs by +517.884s
AV sync issue in stream 0 at 1:12:05.688 : video frame timecode differs by +517.884s
AV sync issue in stream 0 at 1:12:06.271 : video frame timecode differs by +517.884s
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '386459648'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '386459648'
Re: true detective
Post by Woodstock » Tue Dec 19, 2017 2:35 pm
"Looks flawless", but did you clean it anyway?
tim909
Re: true detective
Post by tim909 » Tue Dec 19, 2017 10:49 pm
Woodstock wrote:"Looks flawless", but did you clean it anyway?
yes
MadisonJeepID
Re: true detective
Post by MadisonJeepID » Sun Dec 24, 2017 5:30 pm
I had the same issue. Cleaned and still got the error on certain tracs.
