Hi all
I managed to rip Ghostbusters today, and when I went to play it, my PC crawled.
Specs as follows:
i7 4770
GTX 1070
32GB DDR3.
I've enabled hardware acceleration in VLC, but all I get is stuttering video (disabled audio as well to see if that helps... it doesn't).
How do I verify that MakeMKV has successfully ripped the file correctly? Do I just assume it has because the file exists?
Playback - blockiness and stuttering
preserve
Re: Playback - blockiness and stuttering
MakeMKV will tell you how many titles are successfully saved after completing the save operation.
If you don't see any errors reported, then the rip should have successfully completed.
Try http://mpv.io instead of VLC.
Using: ASUS BW-16D1HT 3.00
angelgraves13
Try MPC HC/BE with madvr. VLC isn't the best player.
beatsntoons
Thanks! I tried mpv and it played the files perfectly
Cheers!
Cheers!
sharpie00
I'm running into the same issue with my rips.
Can you recommend an alternative for Mac users?
gereral1
Google my name and watch my videos on HDR and madvr and other things to get the video smooth. These videos may help get rid of jitter and dropped frames in madvr with HDR UHD material. I get smooth playback dtsx atmos in 4k UHD HDR on AMD 965 x4 processor (lol) 8 gigs of RAM, win 10, mpcbe, and lav video filter disabled. I use Madvr and works perfect on AMD rx470 video card. This is all covered in my videos......peace. .beatsntoons wrote:Hi all
Specs as follows:
i7 4770
GTX 1070
32GB DDR3.
KayakNate
What are the differences between HC and BE?angelgraves13 wrote:Try MPC HC/BE with madvr. VLC isn't the best player.
gereral1
Be support 10bit full screen and greater surface textures and 2 audio sources at same time. Support gamma as well.KayakNate wrote:What are the differences between HC and BE?angelgraves13 wrote:Try MPC HC/BE with madvr. VLC isn't the best player.
