Playback - blockiness and stuttering
beatsntoons
Post by beatsntoons » Mon Dec 18, 2017 10:22 am
Hi all
I managed to rip Ghostbusters today, and when I went to play it, my PC crawled.
Specs as follows:
i7 4770
GTX 1070
32GB DDR3.
I've enabled hardware acceleration in VLC, but all I get is stuttering video (disabled audio as well to see if that helps... it doesn't).
How do I verify that MakeMKV has successfully ripped the file correctly? Do I just assume it has because the file exists?
preserve
Re: Playback - blockiness and stuttering
Post by preserve » Mon Dec 18, 2017 4:46 pm
MakeMKV will tell you how many titles are successfully saved after completing the save operation.
If you don't see any errors reported, then the rip should have successfully completed.
Try http://mpv.io instead of VLC.
Using: ASUS BW-16D1HT 3.00
angelgraves13
Post by angelgraves13 » Mon Dec 18, 2017 7:38 pm
Try MPC HC/BE with madvr. VLC isn't the best player.
beatsntoons
Post by beatsntoons » Tue Dec 19, 2017 3:45 am
Thanks! I tried mpv and it played the files perfectly :)
Cheers!
sharpie00
Post by sharpie00 » Wed Dec 27, 2017 2:34 pm
I'm running into the same issue with my rips.
Can you recommend an alternative for Mac users?
gereral1
Post by gereral1 » Wed Jan 17, 2018 3:57 am
beatsntoons wrote:Hi all
Specs as follows:
i7 4770
GTX 1070
32GB DDR3.
Google my name and watch my videos on HDR and madvr and other things to get the video smooth. These videos may help get rid of jitter and dropped frames in madvr with HDR UHD material. I get smooth playback dtsx atmos in 4k UHD HDR on AMD 965 x4 processor (lol) 8 gigs of RAM, win 10, mpcbe, and lav video filter disabled. I use Madvr and works perfect on AMD rx470 video card. This is all covered in my videos......peace. .
KayakNate
Post by KayakNate » Wed Jan 17, 2018 8:13 pm
angelgraves13 wrote:Try MPC HC/BE with madvr. VLC isn't the best player.
What are the differences between HC and BE?
gereral1
Post by gereral1 » Wed Jan 17, 2018 8:24 pm
Be support 10bit full screen and greater surface textures and 2 audio sources at same time. Support gamma as well.
