SEG_FPL_MainFeature vs. FPL_MainFeature?
Cornstick
What's the difference between these two?
preserve
Re: SEG_FPL_MainFeature vs. FPL_MainFeature?
This is Java title naming used on movies such as Hunger Games, Divergent Series, etc... I forget if it's just Entertainment One, or if it's based on the studio.
The one you want is probably FPL_MainFeature, although I don't remember seeing SEG variations for the main feature on the titles I have that use this type of coding. (I've seen SEG variations for SF - Special Feature - list items, but I don't remember the difference if any offhand.)
What's the movie?
Checking the runtime as well as the segment map is one way to figure out what's up.
If the segment map is comprised of multiple pieces and there's a difference, you could find and rip just the piece(s) that's different to see what it is.
The more info you provide, the more likely it is that someone will help you.
I tried to figure out these namings before, this is what I thought:
SEG - segment?
SF - special feature?
FPL - feature play list?
What's the movie?
SEG - segment?
Using: ASUS BW-16D1HT 3.00
