1 chapter, 0.9MB?
duffgardens
1 chapter, 0.9MB?
Post by duffgardens » Wed Dec 13, 2017 8:40 am
OS device name: /dev/rdisk7
Current profile: DVD+R DL
Product: BDDVDRW CT10N
Revision: WA02
Serial number: K0088M93137
Firmware date: 2008-08-11 12:34:56
Disc Information
Label: BladeRunner
Timestamp: 2017-11-01 10:25:54
Data capacity: 7.2 Gb
Disc type: DVD-ROM
Disc size: 120mm
Number of layers: 2 (OTP)
MakeMKV v1.10.8 darwin(x64-release) started
Debug logging enabled, log will be saved as /Users/xxxx/MakeMKV_log.txt
Optical drive "DVD+R-DL HL-DT-ST DVD-RW GH41N PQ04d" opened in OS access mode.
Optical drive "BD-ROM HL-DT-ST BDDVDRW CT10N WA02d" opened in OS access mode.
DEBUG: Code 0 at qVQM1'P_xNYX'Gv3~bqa$+/'B:121263153
Calculated BUP offset for VTS #0 does not match one in IFO header.
DEBUG: Code 44 at I-3VGY'}BLG ]1:29404740
DEBUG: Code 0 at :vcVHD'sPv<M7v'`@:29393953
DEBUG: Code 2 at oXjk?=2K0/Sw},Ge>:29395034
Calculated BUP offset for VTS #2 does not match one in IFO header.
DEBUG: Code 1 at I-3VGY'}BLG ]1:29395356
Title #1 was added (1 cell(s), 0:00:01)
Title #1 with special attributes was skipped
Title #2 with special attributes was skipped
Title #3 with special attributes was skipped
Re: 1 chapter, 0.9MB?
Post by Woodstock » Fri Dec 15, 2017 1:48 am
Is this another "screener disk" ?
Mike will need the information asked for in the FAQ in my signature. Send it to support@makemkv.com for review.
duffgardens
Post by duffgardens » Sat Dec 16, 2017 12:36 am
yes, the two i've posted about are screeners. i don't own a proper dvd player.
i did have good results with 2 billboards, the meyerowitz stories, shape of water and battle of the sexes.
i'll submit the materials and as always i have been very happy with this product and would buy it every year
if i had to :D
