Hacksaw Ridge Retail decode errors
asr101
Post by asr101 »
Hello:
MakeMKV failed to decode the main feature on the retail version of Hacksaw Ridge. It did find some of the special features, previews, etc. It said the main feature was too difficult. I wonder if it is the latest build of MakeMKV because it seems earlier versions decoded it. I thought perhaps it was Java issue but I tried another disc and JRE launched and MakeMKV decoded everything perfectly.
Here is the log output:
MakeMKV v1.10.8 darwin(x64-release) started
Debug logging enabled,
log will be saved as /Users/andrew/MakeMKV_log.txt
Optical drive "BD-RE HL-DT-ST BD-RE BE14NU40 1.01d" opened in OS access mode.
DEBUG: Code 10551300 at a8p@2$#7v1>jb^%~:29405752
DEBUG: Code 0 at a8p@2$#7v1>jb^%~:29406741
DEBUG: Code 0 at Q+<~;Ye{kbpO&txw&a:29394229
CellWalk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
Cells 1-1 were removed from title start
Cells 19-19 were removed from title end
Title #1 was added (17 cell(s), 2:19:03)
Title #10 was added (1 cell(s), 0:02:08)
Title #11 was added (1 cell(s), 0:01:52)
Title #12 was added (1 cell(s), 0:01:47)
Title #13 was added (1 cell(s), 0:02:43)
Title #14 was added (1 cell(s), 0:02:43)
Can't locate a cell for VTS 12 TTN 1 PGCN 1 PGN 2
Title #20 was added (22 cell(s), 2:29:29)
Title #22 was added (17 cell(s), 2:19:03)
Title 1 in VTS 15 is equal to title 1 and was skipped
Title 2 in VTS 8 is equal to title 1 and was skipped
Re: Hacksaw Ridge Retail decode errors
Actually, it found both features you're wondering about:
One algorithm didn't work so another was used, and the titles were found.
asr101
Post by asr101 »
You are correct. I loaded the wrong disc and was expecting a different file.
