I am using Linux Ubuntu 16.04. I have downloaded and extracted: /download/makemkv-bin-1.10.7.tar.gz, /download/makemkv-oss-1.10.7.tar.gz. I then entered the code: sudo apt-get install build-essential pkg-config libc6-dev libssl-dev libexpat1-dev libavcodec-dev libgl1-mesa-dev libqt4-dev. I am attempting to do the next steps and am stuck. The directions say to "unpack" (which I thought I already did when I extracted the files). and enter:
./configure
make
sudo make install
I get error messages and not found. Please explain what I am missing. Obviously I'm missing a step somewhere. Thank you!
Stuck on installation
tim.c
Re: Stuck on installation
Not sure if you fixed your issue.
Basically i ran into the same issue on fedora 24. To get round this i pulled down an older version of ffmpeg, 2.7.7 to be precise which contains libavcodec.so.56 & libavutil.so.54. I'm sure you if you spend some time looking at configure you can just build these two libraries but use the following
Once this completes you can find libavcodec.so.56 libavutil.so.54 and libswresample.so.1 in child directories which is required to satisfy makemkvcon dependances. Copy these three files to /usr/lib64
./configure --enable-shared --disable-static
make
