enzolt
#1
Post
by enzolt » Sat Dec 09, 2017 12:46 am
I am running into a problem.
No matter which blu-ray disk I insert, the program errors out.
I checked Windows logs and there isnt anything in there related to the program nor the SATA disk drive.
Used to be able to use the program with no issues.
I am running the lastest version of Windows 10 (updated last night).
I am also running the latest version of MakeMKV.
Already reinstalled the program but it didnt solve the issue.
enzolt
#2
Post
by enzolt » Sat Dec 09, 2017 2:25 am
Running latest version of JRE.
Even if I just go to settings to enable debug logging, the program crashes.
I uninstalled 1.10.8 and tried to use 1.10.7 and the program still crashes.
It might be something with the latest update of Windows 10.
enzolt
#4
Post
by enzolt » Tue Dec 12, 2017 5:49 pm
I was able to get a debug log out
Debug log started at Tue Dec 12 17:45:22 2017 , written by MakeMKV v1.10.8 win(x64-release)
001005:0000 MakeMKV v1.10.8 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\ivan-gaming/MakeMKV_log.txt
Found java version=1.8.0.152 path=C:\Program Files\Java\jre1.8.0_152\bin\java.exe
003344:0000 Using Java runtime from C:\Program Files\Java\jre1.8.0_152\bin\java.exe
DEBUG: Code 2147483648 at ;;hLaunq39Nxl3aR:29396529
DAFD=PAAAADAAAAEABDQkEGAACAQ==
DCE=guYsQfU5SjU2MMWXsv8O1j0ZLIczdwfaQfPItTVdtHewJs3RY2+KA7+KBKRodJ4XuLxxMEXiYOOGpk4xjk8lhD5aVtZDU+2u/mOJrKedWxO3UMaJWMBOnUNUM23haYNdNuY/b2E0wDCfh/jZy7BffLGeQ13VlhO68g==
DISCID=5EE304C1AB03B40810CD69B1B58471ED461CA4C9
003025:0000 Title #00002.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00003.mpls has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00004.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00011.mpls has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00012.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00016.mpls has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00018.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00019.mpls has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00020.mpls has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00022.mpls has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00023.mpls has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00024.mpls has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00031.mpls has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00041.mpls has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00041.mpls(1) has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00042.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00043.mpls has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00044.mpls has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00045.mpls has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00079.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00080.mpls has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00081.mpls has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00082.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00084.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00084.mpls(1) has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00084.mpls(2) has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00114.mpls has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00115.mpls has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00200.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00377.mpls was added as title #0
003307:0000 File 00411.mpls was added as title #1
003307:0000 File 00450.mpls was added as title #2
003309:0000 Title 00451.mpls is equal to title 00450.mpls and was skipped
003307:0000 File 00451.mpls(1) was added as title #3
003309:0000 Title 00700.mpls is equal to title 00450.mpls and was skipped
003309:0000 Title 00700.mpls(1) is equal to title 00451.mpls(1) and was skipped
003307:0000 File 00701.mpls was added as title #4
003025:0000 Title #00702.mpls has length of 112 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00703.mpls has length of 107 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00895.mpls was added as title #5
003025:0000 Title #00896.mpls has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 00897.mpls was added as title #6
003307:0000 File 00898.mpls was added as title #7
003307:0000 File 00001.mpls was added as title #8
003307:0000 File 00007.mpls was added as title #9
003307:0000 File 00008.mpls was added as title #10
003307:0000 File 00017.mpls was added as title #11
003307:0000 File 00025.mpls was added as title #12
003307:0000 File 00026.mpls was added as title #13
003307:0000 File 00027.mpls was added as title #14
003307:0000 File 00028.mpls was added as title #15
003307:0000 File 00030.mpls was added as title #16
003307:0000 File 00032.mpls was added as title #17
003307:0000 File 00034.mpls was added as title #18
003307:0000 File 00037.mpls was added as title #19
003307:0000 File 00047.mpls was added as title #20
003307:0000 File 00048.mpls was added as title #21
003307:0000 File 00049.mpls was added as title #22
003307:0000 File 00050.mpls was added as title #23
003307:0000 File 00051.mpls was added as title #24
003307:0000 File 00056.mpls was added as title #25
003307:0000 File 00057.mpls was added as title #26
003307:0000 File 00060.mpls was added as title #27
003307:0000 File 00061.mpls was added as title #28
003307:0000 File 00063.mpls was added as title #29
003307:0000 File 00064.mpls was added as title #30
003307:0000 File 00065.mpls was added as title #31
003307:0000 File 00066.mpls was added as title #32
003307:0000 File 00067.mpls was added as title #33
003307:0000 File 00068.mpls was added as title #34
003307:0000 File 00070.mpls was added as title #35
003307:0000 File 00071.mpls was added as title #36
003307:0000 File 00072.mpls was added as title #37
003307:0000 File 00074.mpls was added as title #38
003307:0000 File 00075.mpls was added as title #39
003307:0000 File 00077.mpls was added as title #40
003307:0000 File 00086.mpls was added as title #41
003307:0000 File 00087.mpls was added as title #42
003307:0000 File 00088.mpls was added as title #43
003307:0000 File 00089.mpls was added as title #44
003307:0000 File 00090.mpls was added as title #45
003307:0000 File 00092.mpls was added as title #46
003307:0000 File 00093.mpls was added as title #47
003307:0000 File 00096.mpls was added as title #48
003307:0000 File 00101.mpls was added as title #49
003307:0000 File 00102.mpls was added as title #50
003307:0000 File 00104.mpls was added as title #51
003307:0000 File 00107.mpls was added as title #52
003307:0000 File 00108.mpls was added as title #53
003307:0000 File 00112.mpls was added as title #54
003307:0000 File 00113.mpls was added as title #55
003307:0000 File 00117.mpls was added as title #56
003307:0000 File 00124.mpls was added as title #57
003307:0000 File 00125.mpls was added as title #58
003307:0000 File 00127.mpls was added as title #59
003307:0000 File 00128.mpls was added as title #60
003307:0000 File 00130.mpls was added as title #61
003307:0000 File 00132.mpls was added as title #62
003307:0000 File 00137.mpls was added as title #63
003307:0000 File 00142.mpls was added as title #64
003307:0000 File 00143.mpls was added as title #65
003307:0000 File 00144.mpls was added as title #66
003307:0000 File 00151.mpls was added as title #67
003307:0000 File 00152.mpls was added as title #68
003307:0000 File 00157.mpls was added as title #69
003307:0000 File 00161.mpls was added as title #70
003307:0000 File 00165.mpls was added as title #71
003307:0000 File 00170.mpls was added as title #72
003307:0000 File 00174.mpls was added as title #73
003307:0000 File 00175.mpls was added as title #74
003307:0000 File 00181.mpls was added as title #75
003307:0000 File 00187.mpls was added as title #76
003307:0000 File 00189.mpls was added as title #77
003307:0000 File 00196.mpls was added as title #78
003307:0000 File 00197.mpls was added as title #79
003307:0000 File 00203.mpls was added as title #80
003307:0000 File 00204.mpls was added as title #81
003307:0000 File 00206.mpls was added as title #82
003307:0000 File 00207.mpls was added as title #83
003307:0000 File 00209.mpls was added as title #84
003307:0000 File 00212.mpls was added as title #85
003307:0000 File 00217.mpls was added as title #86
003307:0000 File 00218.mpls was added as title #87
003307:0000 File 00220.mpls was added as title #88
003307:0000 File 00222.mpls was added as title #89
003307:0000 File 00223.mpls was added as title #90
003307:0000 File 00225.mpls was added as title #91
003307:0000 File 00226.mpls was added as title #92
003307:0000 File 00228.mpls was added as title #93
003307:0000 File 00234.mpls was added as title #94
003307:0000 File 00235.mpls was added as title #95
003307:0000 File 00236.mpls was added as title #96
003307:0000 File 00238.mpls was added as title #97
003307:0000 File 00242.mpls was added as title #98
003307:0000 File 00243.mpls was added as title #99
003307:0000 File 00251.mpls was added as title #100
003307:0000 File 00254.mpls was added as title #101
003307:0000 File 00261.mpls was added as title #102
003307:0000 File 00263.mpls was added as title #103
003307:0000 File 00264.mpls was added as title #104
003307:0000 File 00265.mpls was added as title #105
003307:0000 File 00269.mpls was added as title #106
003307:0000 File 00270.mpls was added as title #107
003307:0000 File 00271.mpls was added as title #108
003307:0000 File 00273.mpls was added as title #109
003307:0000 File 00274.mpls was added as title #110
003307:0000 File 00278.mpls was added as title #111
003307:0000 File 00279.mpls was added as title #112
003307:0000 File 00281.mpls was added as title #113
003307:0000 File 00282.mpls was added as title #114
003307:0000 File 00285.mpls was added as title #115
003307:0000 File 00286.mpls was added as title #116
003307:0000 File 00290.mpls was added as title #117
003307:0000 File 00291.mpls was added as title #118
003307:0000 File 00294.mpls was added as title #119
003307:0000 File 00297.mpls was added as title #120
003307:0000 File 00299.mpls was added as title #121
003307:0000 File 00300.mpls was added as title #122
003307:0000 File 00301.mpls was added as title #123
003307:0000 File 00302.mpls was added as title #124
003307:0000 File 00309.mpls was added as title #125
003307:0000 File 00312.mpls was added as title #126
003307:0000 File 00314.mpls was added as title #127
003307:0000 File 00318.mpls was added as title #128
003307:0000 File 00319.mpls was added as title #129
003307:0000 File 00322.mpls was added as title #130
003307:0000 File 00324.mpls was added as title #131
003307:0000 File 00326.mpls was added as title #132
003307:0000 File 00329.mpls was added as title #133
003307:0000 File 00330.mpls was added as title #134
003307:0000 File 00332.mpls was added as title #135
003307:0000 File 00338.mpls was added as title #136
003307:0000 File 00339.mpls was added as title #137
003307:0000 File 00342.mpls was added as title #138
003307:0000 File 00343.mpls was added as title #139
003307:0000 File 00348.mpls was added as title #140
003307:0000 File 00350.mpls was added as title #141
003307:0000 File 00353.mpls was added as title #142
003307:0000 File 00358.mpls was added as title #143
003307:0000 File 00359.mpls was added as title #144
003307:0000 File 00361.mpls was added as title #145
003307:0000 File 00364.mpls was added as title #146
003307:0000 File 00365.mpls was added as title #147
003307:0000 File 00366.mpls was added as title #148
003307:0000 File 00370.mpls was added as title #149
003307:0000 File 00372.mpls was added as title #150
003307:0000 File 00373.mpls was added as title #151
003307:0000 File 00378.mpls was added as title #152
003307:0000 File 00379.mpls was added as title #153
003307:0000 File 00381.mpls was added as title #154
003307:0000 File 00383.mpls was added as title #155
003307:0000 File 00385.mpls was added as title #156
003307:0000 File 00389.mpls was added as title #157
003307:0000 File 00390.mpls was added as title #158
003307:0000 File 00392.mpls was added as title #159
003307:0000 File 00397.mpls was added as title #160
003307:0000 File 00398.mpls was added as title #161
003307:0000 File 00399.mpls was added as title #162
003307:0000 File 00400.mpls was added as title #163
003307:0000 File 00401.mpls was added as title #164
003307:0000 File 00403.mpls was added as title #165
003307:0000 File 00406.mpls was added as title #166
003307:0000 File 00408.mpls was added as title #167
003307:0000 File 00410.mpls was added as title #168
003307:0000 File 00417.mpls was added as title #169
003307:0000 File 00418.mpls was added as title #170
003307:0000 File 00419.mpls was added as title #171
003307:0000 File 00425.mpls was added as title #172
003307:0000 File 00428.mpls was added as title #173
003307:0000 File 00429.mpls was added as title #174
003307:0000 File 00433.mpls was added as title #175
003307:0000 File 00436.mpls was added as title #176
003307:0000 File 00438.mpls was added as title #177
003307:0000 File 00440.mpls was added as title #178
003307:0000 File 00444.mpls was added as title #179
003307:0000 File 00446.mpls was added as title #180
003307:0000 File 00455.mpls was added as title #181
003307:0000 File 00459.mpls was added as title #182
003307:0000 File 00464.mpls was added as title #183
003307:0000 File 00465.mpls was added as title #184
003307:0000 File 00466.mpls was added as title #185
003307:0000 File 00467.mpls was added as title #186
003307:0000 File 00468.mpls was added as title #187
003307:0000 File 00470.mpls was added as title #188
003307:0000 File 00471.mpls was added as title #189
003307:0000 File 00472.mpls was added as title #190
003307:0000 File 00473.mpls was added as title #191
003307:0000 File 00474.mpls was added as title #192
003307:0000 File 00475.mpls was added as title #193
003307:0000 File 00477.mpls was added as title #194
003307:0000 File 00481.mpls was added as title #195
003307:0000 File 00482.mpls was added as title #196
003307:0000 File 00484.mpls was added as title #197
003307:0000 File 00486.mpls was added as title #198
003307:0000 File 00490.mpls was added as title #199
003307:0000 File 00494.mpls was added as title #200
003307:0000 File 00496.mpls was added as title #201
003307:0000 File 00499.mpls was added as title #202
003307:0000 File 00500.mpls was added as title #203
003307:0000 File 00507.mpls was added as title #204
003307:0000 File 00515.mpls was added as title #205
003307:0000 File 00516.mpls was added as title #206
003307:0000 File 00522.mpls was added as title #207
003307:0000 File 00527.mpls was added as title #208
003307:0000 File 00530.mpls was added as title #209
003307:0000 File 00535.mpls was added as title #210
003307:0000 File 00536.mpls was added as title #211
003307:0000 File 00539.mpls was added as title #212
003307:0000 File 00543.mpls was added as title #213
003307:0000 File 00544.mpls was added as title #214
003307:0000 File 00545.mpls was added as title #215
003307:0000 File 00546.mpls was added as title #216
003307:0000 File 00548.mpls was added as title #217
003307:0000 File 00549.mpls was added as title #218
003307:0000 File 00551.mpls was added as title #219
003307:0000 File 00552.mpls was added as title #220
003307:0000 File 00556.mpls was added as title #221
003307:0000 File 00558.mpls was added as title #222
003307:0000 File 00561.mpls was added as title #223
003307:0000 File 00562.mpls was added as title #224
003307:0000 File 00563.mpls was added as title #225
003307:0000 File 00565.mpls was added as title #226
003307:0000 File 00569.mpls was added as title #227
003307:0000 File 00570.mpls was added as title #228
003307:0000 File 00571.mpls was added as title #229
003307:0000 File 00573.mpls was added as title #230
003307:0000 File 00576.mpls was added as title #231
003307:0000 File 00577.mpls was added as title #232
003307:0000 File 00578.mpls was added as title #233
003307:0000 File 00579.mpls was added as title #234
003307:0000 File 00581.mpls was added as title #235
003307:0000 File 00583.mpls was added as title #236
003307:0000 File 00585.mpls was added as title #237
003307:0000 File 00587.mpls was added as title #238
003307:0000 File 00590.mpls was added as title #239
003307:0000 File 00591.mpls was added as title #240
003307:0000 File 00599.mpls was added as title #241
003307:0000 File 00601.mpls was added as title #242
003307:0000 File 00606.mpls was added as title #243
003307:0000 File 00611.mpls was added as title #244
003307:0000 File 00613.mpls was added as title #245
003307:0000 File 00614.mpls was added as title #246
003307:0000 File 00615.mpls was added as title #247
003307:0000 File 00616.mpls was added as title #248
003307:0000 File 00618.mpls was added as title #249
003307:0000 File 00620.mpls was added as title #250
003307:0000 File 00625.mpls was added as title #251
003307:0000 File 00627.mpls was added as title #252
003307:0000 File 00630.mpls was added as title #253
003307:0000 File 00631.mpls was added as title #254
003307:0000 File 00634.mpls was added as title #255
003307:0000 File 00636.mpls was added as title #256
003307:0000 File 00644.mpls was added as title #257
003307:0000 File 00645.mpls was added as title #258
003307:0000 File 00646.mpls was added as title #259
003307:0000 File 00647.mpls was added as title #260
003307:0000 File 00648.mpls was added as title #261
003307:0000 File 00649.mpls was added as title #262
003307:0000 File 00651.mpls was added as title #263
003307:0000 File 00654.mpls was added as title #264
003307:0000 File 00656.mpls was added as title #265
003307:0000 File 00658.mpls was added as title #266
003307:0000 File 00661.mpls was added as title #267
003307:0000 File 00667.mpls was added as title #268
003307:0000 File 00668.mpls was added as title #269
003307:0000 File 00675.mpls was added as title #270
003307:0000 File 00676.mpls was added as title #271
003307:0000 File 00678.mpls was added as title #272
003307:0000 File 00679.mpls was added as title #273
003307:0000 File 00680.mpls was added as title #274
003307:0000 File 00691.mpls was added as title #275
003307:0000 File 00692.mpls was added as title #276
003307:0000 File 00693.mpls was added as title #277
003307:0000 File 00695.mpls was added as title #278
003307:0000 File 00697.mpls was added as title #279
003307:0000 File 00705.mpls was added as title #280
003307:0000 File 00706.mpls was added as title #281
003307:0000 File 00709.mpls was added as title #282
003307:0000 File 00713.mpls was added as title #283
003307:0000 File 00717.mpls was added as title #284
003307:0000 File 00726.mpls was added as title #285
003307:0000 File 00730.mpls was added as title #286
003307:0000 File 00732.mpls was added as title #287
003307:0000 File 00733.mpls was added as title #288
003307:0000 File 00735.mpls was added as title #289
003307:0000 File 00736.mpls was added as title #290
003307:0000 File 00738.mpls was added as title #291
003307:0000 File 00741.mpls was added as title #292
003307:0000 File 00746.mpls was added as title #293
003307:0000 File 00747.mpls was added as title #294
003307:0000 File 00753.mpls was added as title #295
003307:0000 File 00756.mpls was added as title #296
003307:0000 File 00757.mpls was added as title #297
003307:0000 File 00760.mpls was added as title #298
003307:0000 File 00761.mpls was added as title #299
003307:0000 File 00767.mpls was added as title #300
003307:0000 File 00768.mpls was added as title #301
003307:0000 File 00770.mpls was added as title #302
003307:0000 File 00771.mpls was added as title #303
003307:0000 File 00772.mpls was added as title #304
003307:0000 File 00777.mpls was added as title #305
003307:0000 File 00780.mpls was added as title #306
003307:0000 File 00781.mpls was added as title #307
003307:0000 File 00782.mpls was added as title #308
003307:0000 File 00783.mpls was added as title #309
003307:0000 File 00784.mpls was added as title #310
003307:0000 File 00787.mpls was added as title #311
003307:0000 File 00788.mpls was added as title #312
003307:0000 File 00790.mpls was added as title #313
003307:0000 File 00791.mpls was added as title #314
003307:0000 File 00792.mpls was added as title #315
003307:0000 File 00794.mpls was added as title #316
003307:0000 File 00795.mpls was added as title #317
003307:0000 File 00796.mpls was added as title #318
003307:0000 File 00797.mpls was added as title #319
003307:0000 File 00798.mpls was added as title #320
003307:0000 File 00799.mpls was added as title #321
003307:0000 File 00801.mpls was added as title #322
003307:0000 File 00802.mpls was added as title #323
003307:0000 File 00804.mpls was added as title #324
003307:0000 File 00806.mpls was added as title #325
003307:0000 File 00809.mpls was added as title #326
003307:0000 File 00814.mpls was added as title #327
003307:0000 File 00817.mpls was added as title #328
003307:0000 File 00820.mpls was added as title #329
003307:0000 File 00821.mpls was added as title #330
003307:0000 File 00822.mpls was added as title #331
003307:0000 File 00823.mpls was added as title #332
003307:0000 File 00826.mpls was added as title #333
003307:0000 File 00835.mpls was added as title #334
003307:0000 File 00837.mpls was added as title #335
003307:0000 File 00840.mpls was added as title #336
003307:0000 File 00842.mpls was added as title #337
003307:0000 File 00843.mpls was added as title #338
003307:0000 File 00844.mpls was added as title #339
003307:0000 File 00848.mpls was added as title #340
003307:0000 File 00849.mpls was added as title #341
003307:0000 File 00850.mpls was added as title #342
003307:0000 File 00851.mpls was added as title #343
003307:0000 File 00855.mpls was added as title #344
003307:0000 File 00857.mpls was added as title #345
003307:0000 File 00861.mpls was added as title #346
003307:0000 File 00863.mpls was added as title #347
003307:0000 File 00864.mpls was added as title #348
003307:0000 File 00865.mpls was added as title #349
003307:0000 File 00868.mpls was added as title #350
003307:0000 File 00871.mpls was added as title #351
003307:0000 File 00876.mpls was added as title #352
003307:0000 File 00877.mpls was added as title #353
003307:0000 File 00878.mpls was added as title #354
003307:0000 File 00879.mpls was added as title #355
003307:0000 File 00880.mpls was added as title #356
003307:0000 File 00881.mpls was added as title #357
003307:0000 File 00882.mpls was added as title #358
003307:0000 File 00884.mpls was added as title #359
003307:0000 File 00885.mpls was added as title #360
003307:0000 File 00890.mpls was added as title #361
003307:0000 File 00891.mpls was added as title #362
003307:0000 File 00894.mpls was added as title #363
003307:0000 File 00900.mpls was added as title #364
003307:0000 File 00905.mpls was added as title #365
003307:0000 File 00906.mpls was added as title #366
003307:0000 File 00907.mpls was added as title #367
003307:0000 File 00909.mpls was added as title #368
003307:0000 File 00910.mpls was added as title #369
003307:0000 File 00913.mpls was added as title #370
003307:0000 File 00914.mpls was added as title #371
003307:0000 File 00915.mpls was added as title #372
003307:0000 File 00917.mpls was added as title #373
003307:0000 File 00918.mpls was added as title #374
003307:0000 File 00919.mpls was added as title #375
003307:0000 File 00923.mpls was added as title #376
003307:0000 File 00929.mpls was added as title #377
003307:0000 File 00931.mpls was added as title #378
003307:0000 File 00933.mpls was added as title #379
003307:0000 File 00934.mpls was added as title #380
003307:0000 File 00935.mpls was added as title #381
003307:0000 File 00936.mpls was added as title #382
003307:0000 File 00937.mpls was added as title #383
003307:0000 File 00938.mpls was added as title #384
003307:0000 File 00940.mpls was added as title #385
003307:0000 File 00941.mpls was added as title #386
003307:0000 File 00943.mpls was added as title #387
003307:0000 File 00944.mpls was added as title #388
003307:0000 File 00946.mpls was added as title #389
003307:0000 File 00952.mpls was added as title #390
003307:0000 File 00957.mpls was added as title #391
003307:0000 File 00958.mpls was added as title #392
003307:0000 File 00959.mpls was added as title #393
003307:0000 File 00961.mpls was added as title #394
003307:0000 File 00966.mpls was added as title #395
003307:0000 File 00969.mpls was added as title #396
003307:0000 File 00970.mpls was added as title #397
003307:0000 File 00972.mpls was added as title #398
003307:0000 File 00976.mpls was added as title #399
003307:0000 File 00977.mpls was added as title #400
003307:0000 File 00978.mpls was added as title #401
003307:0000 File 00986.mpls was added as title #402
003307:0000 File 00987.mpls was added as title #403
003307:0000 File 00988.mpls was added as title #404
003307:0000 File 00991.mpls was added as title #405
003307:0000 File 00992.mpls was added as title #406
003307:0000 File 00994.mpls was added as title #407
003025:0000 Title #00002.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00006.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00007.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00008.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00010.m2ts has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00011.m2ts has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00014.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00016.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00021.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00022.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00023.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00024.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00025.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00272.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00273.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00274.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00275.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #03985.m2ts has length of 62 seconds which is less than minimum title length of 120 seconds and was therefore skipped
csf9 me=2 ma=0
csf7
Application exited at Tue Dec 12 17:47:59 2017
#5
Post
by Woodstock » Tue Dec 12, 2017 7:10 pm
I was hoping Mike would have seen this topic by now.
Send an email to
support@makemkv.com with a link to this topic. Mike should get back to you with any additional information he needs.
enzolt
#6
Post
by enzolt » Thu Dec 14, 2017 2:29 am
Here is another log file where I dont even have a disk inside.
I simply click the "Preferences" button and the program crashes.
Debug log started at Thu Dec 14 02:25:21 2017 , written by MakeMKV v1.10.8 win(x64-release)
csf9 me=1 ma=0
csf7
Application exited at Thu Dec 14 02:25:59 2017
enzolt
#7
Post
by enzolt » Sat Dec 16, 2017 8:53 pm
Figured out the issue. I suspected it had to do with the Save File location.
I originally ripped to a NAS.
I recently got rid of that NAS from the network.
This resulted in MakeMKV unable to lookup that NAS and this crashes the program.
