Independence Day Resurgence deUHD rip fine?
etc6849
Post by etc6849 » Sun Dec 03, 2017 5:27 pm
Makemkv cannot read the 00801.m2ts file. I tried multiple rips using deUHD and they all rip successfully. I also tried mkvtoolnix.
Can't do a log dump since disc is never opened or I'd provide that.
Picture of where makemkv gets stuck:
https://drive.google.com/file/d/1ATygSX ... sp=sharing
etc6849
Re: Independence Day Resurgence deUHD rip fine?
Post by etc6849 » Sun Dec 03, 2017 9:26 pm
This spreadsheet here indicates others have had an issue with the deuhd rip:
https://docs.google.com/spreadsheets/d/ ... edit#gid=0
"Independence Day: Resurgence US 024543305002 f150c801e8de6e378b73b672c02cd0786e40784a Not Supported 1.0.0.8 DeUHD reports processed, but disc is unplayable; sent files to Arusoft"
Maybe I will just have to wait a month and retry the rip.
etc6849 wrote:Makemkv cannot read the 00801.m2ts file. I tried multiple rips using deUHD and they all rip successfully. I also tried mkvtoolnix.
Post by mike admin » Wed Dec 06, 2017 8:04 pm
What happens when you read the disc directly with MakeMKV, using keys from doom9?
etc6849
Post by etc6849 » Fri Dec 08, 2017 5:34 pm
Thanks, this does open the disc, but then I get the errors below. I've attached the file that is dumped.
I haven't used this method before, perhaps I am doing something wrong?
I downloaded this keydb: http://forum.doom9.org/showthread.php?p ... ost1823531
appended keys from the post to it: http://forum.doom9.org/showthread.php?p ... ost1826296
Then I create a directory to store the key cfg file and set the location under preferences.
MakeMKV v1.10.8 win(x64-release) started
Saved SD dump file as C:/DataKeys/dump_SD_78CA2F59825802034A9C.tgz
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom1'
Saved AACS dump file as C:/DataKeys/MKB20_v61_Independence_Day_Resurgence.tgz
mike admin wrote:What happens when you read the disc directly with MakeMKV, using keys from doom9?
ccutrer
Post by ccutrer » Wed Dec 13, 2017 9:49 pm
This is Independence Day: Resurgence. Its VUK is not in the Doom9 leak.
