I am getting a failed disk error on all the movies, anyone else or ideas? I have the latest copy of MakeMKV.
Movies are
It's the Great Pumpkin Charlie Brown
A Charlie Brown Thanksgiving
A Charlie Brown Christmas
Peanuts Holiday Collection Anniversary Editions
pbrunson
Re: Peanuts Holiday Collection Anniversary Editions
Start with the FAQ link in my signature. If you can show us what the debug log says about the failures, we might be able to help.
yorgo
You may want to check this as well: http://www.makemkv.com/forum2/viewtopic.php?f=8&t=15055. I have successfully ripped these discs to .mkv files.
Help Keep MakeMKV Going - http://www.makemkv.com/buy/
Latest Beta Key - http://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053
Multiple Playlists? - http://www.makemkv.com/forum2/viewtopic ... 6&start=15
pbrunson
Not much in the debug.Woodstock wrote:Start with the FAQ link in my signature. If you can show us what the debug log says about the failures, we might be able to help.
Debug log started at Tue Dec 05 22:44:54 2017 , written by MakeMKV v1.10.8 win(x64-release)
001005:0000 MakeMKV v1.10.8 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\pbrun/MakeMKV_log.txt
001003:0020 DEBUG: Code 0 at a!!XR>gy1D_8g*:121262164
001003:0020 DEBUG: Code 0 at qLJ{l~SI,56Xqt>=:29399611
DEBUG: Code 2147483648 at ;;hLaunq39Nxl3aR:29396529
DAFD=PAAAADAAAAEABDQkEFwECAQ==
DCE=ZNDobzv6aHi7ULUIW3DjTqOA8aLpXfMZEmWG/omybUQqgTltDsOZCeviyfyOOTEhWhf46hhzMkcJxie1G0e531H1j8er3WeoRRDsiuDubVVv3IfMIuehCjJJXyHZDhokw3aicGpXpc3oxiOF2LgieDaXJllBvozq0w==
DCE=vjtxHoOqthxz8VQ3xDpJ4c3PlpXRu4DmIzrkb4p4Zq0vZUi6f4qUXKd7YFAi58eE6wBxIzPJfgBaB31VgQTXtQfdpdG7ykQEFemidmeN1naD/bA62xOMf0W2HzLDNL2Hy0CEkwMtHD3Np1hVkJok7kdQdArIWJ7NkA==
DISCID=99997F02F8731C0BF339814C424C167A81A2FBFD
003025:0000 Title #00071.mpls has length of 1516 seconds which is less than minimum title length of 3000 seconds and was therefore skipped
003025:0000 Title #00081.mpls has length of 1516 seconds which is less than minimum title length of 3000 seconds and was therefore skipped
003025:0000 Title #00072.mpls has length of 1459 seconds which is less than minimum title length of 3000 seconds and was therefore skipped
003025:0000 Title #00082.mpls has length of 1459 seconds which is less than minimum title length of 3000 seconds and was therefore skipped
003025:0000 Title #00000.m2ts has length of 12 seconds which is less than minimum title length of 3000 seconds and was therefore skipped
003025:0000 Title #00001.m2ts has length of 17 seconds which is less than minimum title length of 3000 seconds and was therefore skipped
003025:0000 Title #00003.m2ts has length of 11 seconds which is less than minimum title length of 3000 seconds and was therefore skipped
003025:0000 Title #00010.m2ts has length of 23 seconds which is less than minimum title length of 3000 seconds and was therefore skipped
003025:0000 Title #00026.m2ts has length of 838 seconds which is less than minimum title length of 3000 seconds and was therefore skipped
003025:0000 Title #00020.m2ts has length of 1516 seconds which is less than minimum title length of 3000 seconds and was therefore skipped
003025:0000 Title #00071.m2ts has length of 1459 seconds which is less than minimum title length of 3000 seconds and was therefore skipped
003025:0000 Title #00074.m2ts has length of 134 seconds which is less than minimum title length of 3000 seconds and was therefore skipped
003025:0000 Title #00075.m2ts has length of 134 seconds which is less than minimum title length of 3000 seconds and was therefore skipped
Application exited at Tue Dec 05 22:45:39 2017
yorgo
Reduce the minimum title length to 1000 seconds; you currently have it set to 3000, or 50 minutes, which is much more than the 25 minutes or so for each episode.
pbrunson
Great catch, everything I rip is hour or more. Thank youyorgo wrote:Reduce the minimum title length to 1000 seconds; you currently have it set to 3000, or 50 minutes, which is much more than the 25 minutes or so for each episode.
