Cars DVD not working
Deadlyllama13
Post by Deadlyllama13 »
I am trying to rip "Cars" by Pixar, but can never get the main movie to work. All the extras work, but not the one 6 GB file for the actual movie. The disc is in pretty good shape (i've gotten worse looking discs to work). I've tried 2 different dvd drives and my blu-ray drive. This is what it gives me:
MakeMKV v1.10.8 win(x64-release) started
Title #6 has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #7 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Cells 4-end were skipped due to cell commands (structure protection?)
Title #14 was added (3 cell(s), 0:04:16)
Title #16 has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #17 has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #18 has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #19 has length of 52 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #20 has length of 52 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Cells 35-end were skipped due to cell commands (structure protection?)
Title #21 was added (34 cell(s), 1:56:09)
Title #25 has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #31 has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Cells 9-end were skipped due to cell commands (structure protection?)
Title #32 was added (8 cell(s), 0:15:59)
Title #33 was added (3 cell(s), 0:07:07)
Title #34 has length of 108 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #35 has length of 108 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #36 has length of 108 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Cells 3-end were skipped due to cell commands (structure protection?)
Title #37 was added (2 cell(s), 0:04:31)
Title #39/2 has length of 41 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #39/3 has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #41 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #43/2 has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #45 has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #46 was added (2 cell(s), 0:03:50)
Title #47 has length of 104 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #48 was added (2 cell(s), 0:03:14)
Title #49 has length of 103 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #50 was added (8 cell(s), 0:10:29)
Title #51 has length of 47 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #54 has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #55 has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #56 has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #57 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #58 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #59 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #60 has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory C:/Users/Jason & Libby/Desktop/New folder
Error 'OS error - The I/O device reported an I/O error' occurred while reading '\Device\CdRom1' at offset '12288'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/VIDEO_TS/VTS_10_1.VOB' at offset '12288'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_10_1.VOB' at offset '3750008832'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom1' at offset '3750008832'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_10_1.VOB' at offset '3750270976'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_10_1.VOB' at offset '3750402048'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom1' at offset '3750402048'
Failed to save title 1 to file C:/Users/Jason & Libby/Desktop/New folder/title01.mkv
Encountered 13 errors of type 'Read Error' - see http://www.makemkv.com/errors/dvdread/
0 titles saved, 1 failed
Thank You for any Help.
Jason
Re: Cars DVD not working
The Cars DVD is not a tough nut to crack - it's been ripped by a lot of people, including me.
However, your drive has an issue with the particular one you're trying to rip:
First thing to do is to clean and inspect the disk itself. You have unreadable areas on the disk. Your drive should not be timing out on them, though - it should continue to communicate with the operating system, even if it is retrying the read.
