Calculated BUP offset for VTS #0 does not match one in IFO header.
Calculated BUP offset for VTS #2 does not match one in IFO header.
DEBUG: Code 1 at I-3VGY'}BLG ]1:29395356
Title #1 with special attributes was skipped
Title #2 with special attributes was skipped
can't open disc
Re: can't open disc
What is your minimum title length?
If your minimum title length exceeds the longest title length on the disk, you will get a "failed to open".
I've never seen the "Title #1 with special attributes was skipped" message before.
Gkohler
Re: can't open disc
I’ve been getting this same exact message on a few different screeners. I’ve emailed the issue, hope to get some help on this! Thanks!
weewill
Re: can't open disc
Here's a few more. Screener discs:
MakeMKV v1.10.8 darwin(x64-release) started
Debug logging enabled, log will be saved as /Users/Welles/MakeMKV_log.txt
Optical drive "DVD+R-DL HL-DT-ST DVD-RW GH41N PQ04d" opened in OS access mode.
DEBUG: Code 44 at I-3VGY'}BLG ]1:29404740
DEBUG: Code 0 at :vcVHD'sPv<M7v'`@:29393953
DEBUG: Code 2 at oXjk?=2K0/Sw},Ge>:29395034
Title #1 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3 with special attributes was skipped
DEBUG: Code 233 at JzR27xzgy42YKtZzcsCNmDvU:0
DEBUG: Code 0 at qVQM1'P_xNYX'Gv3~bqa$+/'B:121263153
DEBUG: Code 104 at I-3VGY'}BLG ]1:29404740
Calculated BUP offset for VTS #1 does not match one in IFO header.
Title #0 with special attributes was skipped
Title #3 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #6 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #7 has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #7 with special attributes was skipped
Title #9 has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
duffgardens
Re: can't open disc
i've been having trouble with Darkest Hour, Phantom Thread and Blade Runner 2049
Haven't really cracked the code on manual mode just yet
Gkohler
Re: can't open disc
duffgardens wrote:i've been having trouble with Darkest Hour, Phantom Thread and Blade Runner 2049
That’s weird, I didn’t have a problem ripping any of these.
I ran into an issue with downsizing, Roman Esq, and Thor Ragnarak.
milder
Re: can't open disc
And did you solve anything on Thor, Downsizing, or Roman?
Gkohler
Re: can't open disc
No I didn’t. I’m still waiting to hear back from Makemkv Support. Emailed them a month ago, no response.milder wrote:And did you solve anything on Thor, Downsizing, or Roman?
screenerguy
Re: can't open disc
I found that with the problematic screener discs, if you enable AnyDVD or DVDFabPasskey, rip it to your HD as an ISO and then open that partially broken ISO in MakeMKV your able to get at the disc.
It worked for me on Darkest Hour, Thor etc. I didn't have access to a copy of Phantom Thread but it should work as Darkest Hour is from the same studio. There's slight differences between each disc even within the same studio but there hasn't been one I haven't been able to get thru. Blade Runner was tricky but now the retail disc is widely available.
Not sure about Downsizing as Paramount sent my friend digital links this year instead of physical copies. Good luck on Phantom Thread, I so wish I had a copy of that one. Great film.
Gkohler
Re: can't open disc
Do you know of a ISO program that will run on a mac? anydvd and dvdfabpasskey are windows based..
screenerguy wrote:I found that with the problematic screener discs, if you enable AnyDVD or DVDFabPasskey, rip it to your HD as an ISO and then open that partially broken ISO in MakeMKV your able to get at the disc.
screenerguy
Re: can't open disc
Not sure. All I know is that making a decrypted ISO on some titles was enough to help makemkv find the right title. Guess it fixed the structure protection enough.
