Compile makemkv without gui
unreg
#1 Post by unreg » Sun May 30, 2010 1:46 pm
hi,
how can i compile makemkv without gui?
I dont want to install qt4 just for makemkv, cause i just need makemkvcon for blueray-playback :D
I tried to remove the makemkvgui entries in the makefile, but it doesn't work :/
MartinKG
Re: Compile makemkv without gui
#2 Post by MartinKG » Sun May 30, 2010 5:26 pm
don't know how to compile makemkv w/o gui, but why do you not use xbmc ?
http://bloggingabout.com/bluray-playbac ... linux.html
unreg
#3 Post by unreg » Mon May 31, 2010 4:49 pm
hi, thx for the link.
xmbc sounds interesting, i will give it a trie if i fail to get it to work with xine :)
I already compiled makemkv successful without gui (i can post the makefile, if someone needs it), but the playback of Avatar on xine is reeeaaalllyy slow.
Is this normal? I have a Intel i7 820QM, which should be fast enough :(
(PowerDVD on Win7 plays Avatar without lags at 15% CPU load)
PhoenixRevived
#4 Post by PhoenixRevived » Wed Jun 09, 2010 10:25 pm
I would appreciate your instructions for building without GUI. Will let you know how I fare with Avatar once I am up and running.
hansooloo
#5 Post by hansooloo » Tue Aug 07, 2012 9:45 pm
Appreciate if you could provide the console only Makefile.
