MakeMKV 1.10.8 and macOS High Sierra 10.13.1
robegian
Post by robegian » Thu Nov 30, 2017 8:14 pm
when I try to use the provided serial number for the beta version of MakeMKV, I get the warning message:
"Evaluation period has expired. Please purchase an activation key [etc.]".
If I re-enter the serial number, close the application and re-run it, I get this warning message instead:
"This application version is too old. Plese download the latest version [etc.]".
And the application quits.
Any workaround?
Thanks in advance :-)
Re: MakeMKV 1.10.8 and macOS High Sierra 10.13.1
Post by Woodstock » Thu Nov 30, 2017 8:22 pm
This is because the beta key expired yesterday.
If you are not inclined to buy a permanent key, until Mike replaces the beta key you can start MakeMKV by setting your system date back to 11/27 or so, start MakeMKV, then put the date back to current.
robegian
Post by robegian » Thu Nov 30, 2017 8:23 pm
OK, thanks. The thing is, I've downloaded MakeMKV 1.10.8 today, so I wasn't expecting that.
Post by Woodstock » Thu Nov 30, 2017 11:24 pm
Probably no one expected it, since .8 was released just 12 days ago, but, apparently Mike didn't update the beta key at the same time.
nancy.mcfarlin
Post by nancy.mcfarlin » Fri Dec 01, 2017 5:19 pm
So, how does one go about purchasing a permanent key?
Post by d00zah » Fri Dec 01, 2017 5:36 pm
Help > Purchase (from the menu bar) sends you to /buy/
