SCSI errors
theophile
SCSI errors
Post by theophile » Wed Jun 09, 2010 3:44 am
I first tried MakeMKV a couple months ago at version 1.4.11 and couldn't get past the authentication failure errors. My posts are in this thread. I just downloaded 1.5.6 hoping maybe I would be in luck. Unfortunately not. I seem to be getting the same error as before.
Debug log started at Wed Jun  9 03:33:04 2010 , written by MakeMKV v1.5.6 beta linux(x64-release)
001005:0000 MakeMKV v1.5.6 beta linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /home/theophile/MakeMKV_log.txt
005050:0000 Evaluation version, 30 day(s) out of 30 remaining
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occured while issuing SCSI command A30..00200744100720..0B2AED615C1EB85FA0C0CB4D7CEA02A0867 to device 'SG:dev_11:0'
001003:0020 DEBUG: Code 0 at wD\_Iah:L4sr~M5}8H]2:29394390
001003:0020 DEBUG: Code 0 at )o6i*0S9\K])3YAtE :29394183
001003:0020 DEBUG: Code 0 at )o6i*0S9\K])3YAtE :213130191
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occured while issuing SCSI command A30..00200744100720..05E0B96D10712C3C678865C181C3E928978 to device 'SG:dev_11:0'
001003:0020 DEBUG: Code 1 at )o6i*0S9\K])3YAtE :213130191
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occured while issuing SCSI command A30..00200744100720..02090F250C1625D7F9646C702701C842D52 to device 'SG:dev_11:0'
001003:0020 DEBUG: Code 2 at )o6i*0S9\K])3YAtE :213130191
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occured while issuing SCSI command A30..00200744100720..0853EDE3E70CC6513447F9FED5DE5CD514A to device 'SG:dev_11:0'
001003:0020 DEBUG: Code 3 at )o6i*0S9\K])3YAtE :213130191
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occured while issuing SCSI command A30..00200744100720..082371A742549579E7DA890555964E4D2C8 to device 'SG:dev_11:0'
001003:0020 DEBUG: Code 4 at )o6i*0S9\K])3YAtE :213130191
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occured while issuing SCSI command A30..00200744100720..0B947E27D467E7B6B905D266349ACF3CF5B to device 'SG:dev_11:0'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occured while issuing SCSI command AD010..080002440 to device 'SG:dev_11:0'
001003:0020 DEBUG: Code 0 at wD\_Iah:L4sr~M5}8H]2:29393930
001003:0020 DEBUG: Code 0 at )o6i*0S9\K])3YAtE :121262716
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occured while issuing SCSI command A30..00200744100720..09194E011D131FDBAE63849B46FAAA61EBC to device 'SG:dev_11:0'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occured while issuing SCSI command A30..00200744100720..095EB41401F48029DCA61C0C4079B24119D to device 'SG:dev_11:0'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occured while issuing SCSI command A30..00200744100720..0A8B6DAB01670CF002C92AC0CA123E46F8D to device 'SG:dev_11:0'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occured while issuing SCSI command A30..00200744100720..04E2C8964520F46DC6C281945687A623469 to device 'SG:dev_11:0'
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
003303:0000 The volume key is unknown for this disc - video can't be decrypted
001003:0020 DEBUG: Code 0 at N}VJWM/!5`(sz;@v0.d:213131778
001003:0020 DEBUG: Code 0 at N}VJWM/!5`(sz;@v0.d:121265131
Application exited at Wed Jun  9 03:34:04 2010
This same hardware works using AnyDVD HD under Windows in VirtualBox so I don't think the drive is bricked. Is there anything I can do?
Re: SCSI errors
Post by mike admin » Fri Jun 11, 2010 10:38 am
Is this external drive?
nwspmp
Re: SCSI errors
Post by nwspmp » Fri Jun 11, 2010 8:56 pm
I had a very similar error recently.
MakeMKV has been running wonderfully on my Linux x64 machine and has decrypted everything I've thrown at it. I recently updated to 1.5.6 and it got through three Blu-Rays but then started throwing the same style errors on mine. Specifically, the error with the SCSI commands and the "Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive" error. So, I thought it might be an issue with the disc (Firefly Disc 3) but thought that it wasn't likely that that particular disc would have a problem with authentication when the disc 1 and disc 2 from the same set worked beautifully. So, I threw disc 2 back in, which had worked perfectly instantly before, and it started throwing the same errors, even though nothing had changed.
Was about to rip out the drive and update the firmware on a Windows machine at work, but decided to back the software rev and try that. I only had the BIN and OSS for 1.5.1, so I reinstalled those, and it worked perfectly with Disc 3 now.
theophile
Re: SCSI errors
Post by theophile » Sat Jun 12, 2010 4:07 am
No, this is not an external drive. It's a SATA drive that identifies as "SUNEXT BDROM V8402BH98." I get these same errors when running as root.
Re: SCSI errors
Post by mike admin » Thu Jun 17, 2010 9:59 am
Ouch, if 1.5.1 works and 1.5.6 don't then it's a clear problem with MakeMKV. Do you get the same error with windows version under virtualbox?
nwspmp
Re: SCSI errors
Post by nwspmp » Tue Jun 22, 2010 9:07 pm
Not sure, as none of my home machines have run Windows since early 2002 :) (edit: just noticed that you responded to the original poster; my bad)
I'll pull the drive, and bring it up to a work machine with Windows on it and test it with 1.5.6.
I'll also throw the drive in my MacPro and see if it gives the errors or not.
Thank you for the great software!
nwspmp
Re: SCSI errors
Post by nwspmp » Thu Jun 24, 2010 9:50 pm
Is there any chance of downloading 1.5.5 to test that one on my system?
