Evaluation period has expired, shareware functionality unavailable.
This is my debug file:
Debug log started at Thu Nov 30 00:32:36 2017 , written by MakeMKV v1.10.8 win(x86-release)
001005:0000 MakeMKV v1.10.8 win(x86-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Administrator/MakeMKV_log.txt
005055:0000 Evaluation period has expired, shareware functionality unavailable.
005052:0204 Evaluation period has expired. Please purchase an activation key if you've found this application useful. You may still use all free functionality without any restrictions.
001003:0020 DEBUG: Code 0 at #ao"=)1rG`OD',aM:121263912
001003:0020 DEBUG: Code 0 at #ao"=)1rG`OD',aM:213134009
001003:0020 DEBUG: Code 233 at 8Ziq/29bLAQKQjMrjQebRJ7D:0
001003:0020 DEBUG: Code 233 at jveTYXoN1b6PRLnVf0HCSfT6:0
Application exited at Thu Nov 30 00:33:52 2017
Blu Ray failure
Re: Blu Ray failure
Get the beta key from here: http://makemkv.com/forum2/viewtopic.php?f=5&t=1053
Go to Help->Register, and put the beta key in, then click OK. This should reset the 30-day timer.
Or, you can purchase a permanent key, and not have to worry about the beta key expiring shortly.
If Mike doesn't post a new beta key in the next few days, you may need to set your computer DATE back a few days, start MakeMKV, then reset the date. MakeMKV checks for expiration only on start-up.
Amincey
Re: Blu Ray failure
This only happens when trying to do a blu ray, works fine with DVD's
Amincey
Re: Blu Ray failure
Update:
Check program again and even though I had installed posted registration code it still did not work. Code was from 2 days ago.
Got new code that was released today and program works fine.
Thank you
Thank you
