Billy Lynn's Long Halftime Walk (UK) failing to Rip
danBoi2016
Re: Billy Lynn's Long Halftime Walk (UK) failing to Rip
And the error messages were ... ? Since you posted in the UHD section, did you send the testdump file to Mike, as requested?
yorgo
Also, what are you using to de-encrypt? Your title is not listed on DeUHD's site so it would be helpful to know what tool.
Help Keep MakeMKV Going - http://www.makemkv.com/buy/
Latest Beta Key - http://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053
Multiple Playlists? - http://www.makemkv.com/forum2/viewtopic ... 6&start=15
danBoi2016
its Billy Lynn's Long Halftime Walk and it is on the DEUHD Website, they supported it on Friday 24/11yorgo wrote:Also, what are you using to de-encrypt? Your title is not listed on DeUHD's site so it would be helpful to know what tool.
yorgo
Thank you for clarifying, should have searched for it since it wasn't on their published list page.danBoi2016 wrote:its Billy Lynn's Long Halftime Walk and it is on the DEUHD Website, they supported it on Friday 24/11yorgo wrote:Also, what are you using to de-encrypt? Your title is not listed on DeUHD's site so it would be helpful to know what tool.
danBoi2016
it should be on there on monday 27/11
captin
Tried Billy Lynn with v 1.10.9 (on Mac) and it gets 70% of the way through the rip and beachballs, need to kill makemkv.
It's progress from 1.10.8 which wouldn't open the disk at all.
