Help me out here; I'm not seeing the error. I was able to save off the file I needed, but I'd like to know what the problem maybe for the future. I've seen other threads on Men in Black, but no definite conclusion.
Debug log started at Sun Nov 19 19:39:36 2017 , written by MakeMKV v1.10.8 win(x64-release)
001005:0000 MakeMKV v1.10.8 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\User/MakeMKV_log.txt
005072:0000 Backing up disc into folder "C:/temp/MEN_IN_BLACK"
DEBUG: Code 2147483648 at ;;hLaunq39Nxl3aR:29396529
DAFD=PAAAADAAAAEABDQkEFwECAQ==
DCE=lADvUhfqSMWxdzGtOtYIf3A/RPOXkSZr7u93sOpC8tlCXwFXYOoyYyOQB3xRjKnIpFzC+YgRf18CSJpgj2+9IaY8E2zUygHrPbYS8X9gGXRC3lwUFYg6VLT0gtL8L02rvgmYWjWkErkPK+Wl3M0jH7ZM2BucKPPXxA==
DCE=M3kc/mGFd66lYILTF5EvjsTcYz+RXvwCnBKijULZizLrtQmOs65YXD//zl+c7GMoed1obpHdxVPiirgcKe5WEOC02ouzkHCZUGzkTEXqK09wXiLLjrsQLPBgUvawFdWfdF8uC37YPmX7O5TphZBpuxtWVP4MP9N4Vw==
001003:0020 DEBUG: Code 0 at qLJ{l~SI,56Xqt>=:213140104
001003:0020 DEBUG: Code 0 at h(BZV-JrIjt/1~;5p:29395655
001003:0020 DEBUG: Code 0 at qOI*=wx5:j{WPf8Pod3:213134354
001003:0020 DEBUG: Code 0 at qOI*=wx5:j{WPf8Pod3:29397564
001003:0020 DEBUG: Code 0 at <0W<vOVSs.X)9gR.Buo#:213133319
005069:0080 Backup failed
005080:0204 Backup failed.
Men in Black Backup Failed
Re: Men in Black Backup Failed
"Backup" will fail if any part of the disk is unreadable. The lack of mention of playlist or transport stream files in the log indicates to me that it didn't get to those when it hit an error.
Try this - instead of doing a back up, use the "Open" button, and try saving the individual titles to MKV files. If that succeeds, the issue is in some of the control tracks, which would make the backup function fail.
The entire BD MIB series can be ripped, so it is likely a secondary issue, such as a badly placed smudged fingerprint.
