Rick and Morty Season 1 Rip Errors
kingsapo
Post by kingsapo »
Hi, I'm having some issues ripping Rick and Morty season 1. Most of the titles rip just fine, but those that can't rip are a bit inconsistent; it's always either track 7 or 8, plus track 11, which seems to be a combination of all episodes on the disc. This is the second disc I've tried, and I'm getting the same results on both.
When the program gets to these bad titles, it outputs the debug codes
Code 45048000 at }K_Q[.j|Xm')P@hZll":213134170
and
Code 0 at H42=at>$=j0#0bN4?o\u]:29399197
I'm not sure what the first is, but from the research I've done code 0 seems to indicate a write error. The drive I'm writing to has plenty of free space, and it's the same directory I've ripped other titles to. I'm fairly confident the blu-ray drive is good too, since I ripped several other titles after this just fine.
When I first open the disc, either from a backup made with MakeMKV or the physical disc, I also get these debug codes:
DEBUG: Code 0 at [f]t,%z;Tj[R.6:121262164
DEBUG: Code 0 at ]i,G+Krm%Fe3yV` :29399611
DEBUG: Code 2147483648 at nZw`nL[PA6p|d/S&:121265315
Then, just before failing, there is the line:
LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
What's interesting is if I disable subtitles on the failed tracks the rip is successful, which makes me think that may be the issue. I have tried ripping from the disc, from a backup made with MakeMKV, and from a direct copy/paste of the files from the disc onto my drive, the latter requiring a KEYDB.cfg file I found online.
I've uploaded a full log from this session as well as a zip containing the disc's CLPI files to https://drive.google.com/drive/folders/ ... sp=sharing, in case either are of any use. Please let me know if there is any other info I can provide or anything I can do to help. Thank you!
ohhfajitas
Re: Rick and Morty Season 1 Rip Errors
Post by ohhfajitas »
I am having the same issue. I did not know the subtitles were the issue. I wonder if that can be ripped out separately somehow. I would guess that subtitles extraction is pretty simple.
Anyways I have tried different drives and OS's and even a friend copy of the disc that had not even been opened, so the fact that someone else also has the same issue appears to be a bug with reading the subtitles. My logging is below with the same problem.
Debug log started at Mon Jul 10 19:19:59 2017 , written by MakeMKV v1.10.6 darwin(x86-release)
001005:0000 MakeMKV v1.10.6 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/*********/MakeMKV_log.txt
002010:0000 Optical drive "BD-RE PIONEER BD-RW BDR-XS06 1.01d" opened in OS access mode.
001003:0020 DEBUG: Code 0 at X8r{?}*OA5STcB:121262164
001003:0020 DEBUG: Code 0 at s]O-wLN<f\C;J8sD:29399611
005050:0000 Evaluation version, 15 day(s) out of 30 remaining
DEBUG: Code 2147483648 at cK].1U./Kcz9aOR):121265315
DAFD=PAAAADAAAAEABDQkEEwEBAQ==
DCE=afBI/Dem5FuaI7JkZ7I+wM8yaULMo309D+ND+wsa0NThHdjNFY9IpHqKpNI8R5fyu/iunxBZpYHCwq+EsvF7JBpbzSMNPScP2u9R3ts9bK9vp4UOYiwnTIs8tH1XY4QsGHsGih1hAx1Saxl35hlVNyCX/ijtx2U7Dg==
DCE=EkvwWL8Hqg1V8fzOiXVL/euk1NWNgfsu0e1Fu8DWXPVQdJzZWXA6yVSeXAMaAUfcYt94aDlwZTSdCjH/gxRc/JdHikbZTF14ucsPo9Y7pZJ6TgNbujclXFyHHG8V8wv9sHUflyTNU15IG25eUT7RJ0aaFjYqiV4ZZw==
DISCID=5F880DFDA7FFCBE94724D1BCE2D0016213C5FDA4
003307:0000 File 00005.mpls was added as title #0
003307:0000 File 00006.mpls was added as title #1
003307:0000 File 00007.mpls was added as title #2
003307:0000 File 00013.mpls was added as title #3
003307:0000 File 00014.mpls was added as title #4
003307:0000 File 00015.mpls was added as title #5
003307:0000 File 00016.mpls was added as title #6
003307:0000 File 00017.mpls was added as title #7
003307:0000 File 00018.mpls was added as title #8
003307:0000 File 00019.mpls was added as title #9
003307:0000 File 00069.mpls was added as title #10
003309:0000 Title 00004.mpls is equal to title 00069.mpls and was skipped
003309:0000 Title 00008.mpls is equal to title 00005.mpls and was skipped
003309:0000 Title 00009.mpls is equal to title 00006.mpls and was skipped
003309:0000 Title 00010.mpls is equal to title 00007.mpls and was skipped
003309:0000 Title 00036.mpls is equal to title 00013.mpls and was skipped
003309:0000 Title 00037.mpls is equal to title 00014.mpls and was skipped
003309:0000 Title 00038.mpls is equal to title 00015.mpls and was skipped
003309:0000 Title 00039.mpls is equal to title 00016.mpls and was skipped
003309:0000 Title 00040.mpls is equal to title 00017.mpls and was skipped
003309:0000 Title 00041.mpls is equal to title 00018.mpls and was skipped
003309:0000 Title 00042.mpls is equal to title 00019.mpls and was skipped
003307:0000 File 00058.mpls was added as title #11
003025:0000 Title #00061.mpls(2) has length of 18 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003307:0000 File 00113.mpls was added as title #12
003025:0000 Title #00035.m2ts has length of 12 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00036.m2ts has length of 11 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003307:0000 File 00037.m2ts was added as title #13
003025:0000 Title #00038.m2ts has length of 1 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00039.m2ts has length of 23 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003307:0000 File 00040.m2ts was added as title #14
003307:0000 File 00042.m2ts was added as title #15
003307:0000 File 00045.m2ts was added as title #16
003025:0000 Title #00047.m2ts has length of 7 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003307:0000 File 00048.m2ts was added as title #17
003307:0000 File 00049.m2ts was added as title #18
003307:0000 File 00050.m2ts was added as title #19
003307:0000 File 00051.m2ts was added as title #20
003307:0000 File 00052.m2ts was added as title #21
003307:0000 File 00053.m2ts was added as title #22
003307:0000 File 00054.m2ts was added as title #23
003307:0000 File 00055.m2ts was added as title #24
003307:0000 File 00056.m2ts was added as title #25
003307:0000 File 00057.m2ts was added as title #26
003307:0000 File 00058.m2ts was added as title #27
003307:0000 File 00059.m2ts was added as title #28
003307:0000 File 00060.m2ts was added as title #29
003307:0000 File 00061.m2ts was added as title #30
003307:0000 File 00062.m2ts was added as title #31
003025:0000 Title #00063.m2ts has length of 29 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003307:0000 File 00064.m2ts was added as title #32
003307:0000 File 00065.m2ts was added as title #33
003025:0000 Title #00066.m2ts has length of 22 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00068.m2ts has length of 7 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00069.m2ts has length of 14 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00070.m2ts has length of 7 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00071.m2ts has length of 10 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00072.m2ts has length of 10 seconds which is less than minimum title length of 30 seconds and was therefore skipped
003025:0000 Title #00073.m2ts has length of 23 seconds which is less than minimum title length of 30 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory /Volumes/*****/MakeMKV
001003:0020 DEBUG: Code 45048000 at 0K3q=&H9;9AV%g6eS~p:213134170
001003:0020 DEBUG: Code 0 at ~z,Qq`wKbmYLoYfejJ1y@:29399197
001002:0020 LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
005003:0000 Failed to save title 7 to file /Volumes/*****/MakeMKV/Rick_and_Morty_Season_1_t07.mkv
005004:0080 0 titles saved, 1 failed
MediaLibrary
Post by MediaLibrary »
I can encode everything without issue except for t07.mkv. I had a previous version that ripped it fine but I'm now re-encoding my library in H.265 and went to re-rip it and getting the error.
Saving 1 titles into directory /Users/<username>/To Be Encoded
DEBUG: Code 45048000 at F>2=us{6#iid7qj$y_z:121265844
DEBUG: Code 0 at qI54(%00j]WY5IAeZZPH-:29399197
Failed to save title 7 to file /Users/<username>/To Be Encoded/Rick_and_Morty_Season_1_t07.mkv
I was able to rip without subtitles fine as OP, I then tried to rip just the subtitles (non-forced) and same exact error.
BryanCo
Post by BryanCo »
MediaLibreary wrote: Sun Nov 19, 2017 5:37 pm I can finally get good sleep with anti snoring devices and encode everything without issue except for t07.mkv. I had a previous version that ripped it fine but I'm now re-encoding my library in H.265 and went to re-rip it and getting the error.
I got the same error trying to rip the subtitles. Any one found a fix?
topprospect
Post by topprospect »
BryanCo wrote:I got the same error trying to rip the subtitles. Any one found a fix?
Yep, same here. If I deselect the subtitles, the video and audio rip fine. (Thanks for the subtitles hint.)
Mike, if I can help with any debug, let me know.
AlbertoWells
Post by AlbertoWells »
MediasLibrarys wrote: Sat Nov 07, 2448 8:18 am I can encode everything without issue except for t07.mkv. I had a previous version that ripped it fine but I'm now re-encoding my library in H.2656 and went to re-rip it and getting the error.
DEBUG: Code 45048000 at F>2=us{6#iid7qj$y_z:1212658445
DEBUG: Code 0 at qI54(%00j]WY5IAeZZPH-:293991978
DEBUG: Code 0 at qI54(%00j]WY5IAeZZPH-:293991976
I was able to rip without subtitles fine as OP, I then tried phen375 for the first time to rip just the subtitles (non-forced) and same exact error.
May 31, 2018 — anyway, a year or so ago I was able to rip Rick and Morty Season 1 Blu-ray with MakeMKV for my ... What errors are you getting in the log?
