Dolby Vision?
spl147
Dolby Vision?
Post by spl147 » Tue Oct 31, 2017 1:39 pm
with the upcoming version of MakeMKV with Decrypted UHD support, Will it Support Dolby Vision in the container as well?
angelgraves13
Re: Dolby Vision?
Post by angelgraves13 » Tue Nov 14, 2017 1:08 am
Dolby Vision is metadata on top of HDR10, which is also metadata. You can’t separate the metadata if you can’t decode it.
It’ll copy over, but probably won’t play unless you do pass through to a Dolby Vision TV. Currently no program can decide the Dolby Vision layer.
spl147
Re: Dolby Vision?
Post by spl147 » Tue Nov 14, 2017 7:23 pm
angelgraves13 wrote:Dolby Vision is metadata on top of HDR10, which is also metadata. You can’t separate the metadata if you can’t decode it.
actually Dolby Vision is a Seperate Video Track:
when trying to use the other brand UHD ripper it says dolby vision is unsuppported and will be removed.
General
Complete name                            : /Volumes/External_3tb/UltraHD/Transformers The Last Night_UHD/BDMV/STREAM/00008.m2ts
Format                                   : BDAV
Format/Info                              : Blu-ray Video
File size                                : 89.2 GiB
Duration                                 : 2h 34mn
Overall bit rate                         : 82.5 Mbps
Maximum Overall bit rate                 : 109 Mbps
Video #1
Duration                                 : 2h 34mn
Frame rate                               : 23.976 (24000/1001) fps
Mastering display color primaries        : R: x=0.680000 y=0.320000, G: x=0.265000 y=0.690000, B: x=0.150000 y=0.060000, White point: x=0.312700 y=0.329000
Mastering display luminance              : min: 0.0001 cd/m2, max: 1000.0000 cd/m2
Video #2
Duration                                 : 2h 34mn
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Audio #1
Format                                   : TrueHD / AC-3
Format profile                           : TrueHD+Atmos / TrueHD / AC-3
Muxing mode                              : Stream extension
Codec ID                                 : 131
Duration                                 : 2h 34mn
Bit rate mode                            : Variable / Constant
Bit rate                                 : 640 Kbps
Maximum bit rate                         : 6 528 Kbps
Channel(s)                               : Object Based / 8 channels / 6 channels
Channel positions                        : Object Based / Front: L C R, Side: L R, Back: L R, LFE / Front: L C R, Side: L R, LFE
Sampling rate                            :  / 48.0 KHz / 48.0 KHz
Frame rate                               : 31.250 fps (1536 SPF)
Bit depth                                : 16 bits
Stream size                              : 708 MiB (1%)
Audio #2
Codec ID                                 : 129
Duration                                 : 2h 34mn
Bit rate                                 : 640 Kbps
Channel positions                        : Front: L C R, Side: L R, LFE
Sampling rate                            : 48.0 KHz
Bit depth                                : 16 bits
Audio #3
Codec ID                                 : 129
Duration                                 : 2h 34mn
Bit rate                                 : 224 Kbps
Channel(s)                               : 2 channels
Channel positions                        : Front: L R
Bit depth                                : 16 bits
Stream size                              : 248 MiB (0%)
Audio #4
Codec ID                                 : 129
Duration                                 : 2h 34mn
Bit rate                                 : 640 Kbps
Bit depth                                : 16 bits
Audio #5
Codec ID                                 : 129
Duration                                 : 2h 34mn
Bit rate                                 : 640 Kbps
Bit depth                                : 16 bits
Audio #6
Codec ID                                 : 129
Duration                                 : 2h 34mn
Bit rate                                 : 640 Kbps
Bit depth                                : 16 bits
Audio #7
Codec ID                                 : 129
Duration                                 : 2h 34mn
Bit rate                                 : 640 Kbps
Bit depth                                : 16 bits
Text #1
Format                                   : PGS
Codec ID                                 : 144
Text #2
Format                                   : PGS
Codec ID                                 : 144
Text #3
Format                                   : PGS
Codec ID                                 : 144
Text #4
Format                                   : PGS
Codec ID                                 : 144
Text #5
Format                                   : PGS
Codec ID                                 : 144
angelgraves13
Re: Dolby Vision?
Post by angelgraves13 » Thu Nov 16, 2017 8:29 am
It seems you're right. Dolby Vision is a separate video track, so it is unlikely we will be able to remux it. There is currently no way to decode Dolby Vision in software as the standard is not open and no specification is available for reverse engineering. Never say never though....
Re: Dolby Vision?
Post by mike admin » Fri Nov 17, 2017 11:39 pm
If you do have dolby vision discs, please send a testdump per instructions at http://www.makemkv.com/onlinehelp/testdump.html
Meister_Proper
Re: Dolby Vision?
Post by Meister_Proper » Sat Nov 18, 2017 12:20 pm
It seems like the DV videostream is not recognized as a separate track:
The movie is The Fate of the Furious.
The separate stream is missing from the output:
Format version                           : Version 2
File size                                : 43.1 GiB
Duration                                 : 2 h 15 min
Overall bit rate                         : 45.3 Mb/s
Movie name                               : THE FATE OF THE FURIOUS
Encoded date                             : UTC 2017-11-18 11:55:19
Writing application                      : MakeMKV v1.10.8 win(x64-release)
Writing library                          : libmakemkv v1.10.8 (1.3.5/1.4.7) win(x64-release)
Video
ID in the original source medium         : 4113 (0x1011)
Bit rate                                 : 42.0 Mb/s
Bits/(Pixel*Frame)                       : 0.211
Stream size                              : 39.9 GiB (93%)
Mastering display luminance              : min: 0.0050 cd/m2, max: 4000.0000 cd/m2
Maximum Frame-Average Light Level        : 602 cd/m2
Audio
mediainfo of original m2ts:
Format                                   : BDAV
File size                                : 53.1 GiB
Overall bit rate                         : 55.9 Mb/s
Maximum Overall bit rate                 : 109 Mb/s
Video #1
Video #2
Audio #1
I'm creating dump file right now.
//edit:
dump file sent.
//edit2:
v1.10.9 did not add DV support. Its not listed in the changelog, but I wwanted to test anyway.
mbnwa
Re: Dolby Vision?
Post by mbnwa » Wed Jan 17, 2018 5:43 am
I have also sent in the data requested for "The Dark Tower" Dolby Vision UHD
mbnwa
Re: Dolby Vision?
Post by mbnwa » Wed Jan 17, 2018 7:44 am
I have also sent in the data requested for "The Fate of the Furious" Dolby Vision UHD
buffalo master
Re: Dolby Vision?
Post by buffalo master » Sat Apr 21, 2018 5:59 pm
Where do we send dumps? I badly want Dolby Vision support.
B17NNS
Re: Dolby Vision?
Post by B17NNS » Sat Apr 21, 2018 6:40 pm
Anything further on this?
st4evr
Re: Dolby Vision?
Post by st4evr » Sat Apr 21, 2018 8:48 pm
buffalo master wrote:Where do we send dumps? I badly want Dolby Vision support.
You need to read Mike’s post above. He explicitly provides instructions where to send them.
