I purchased makemkv about 6 months ago. I recently formatted my PC and need to reinstalled a registered copy, but they're is no proper login on the makemkv website to valid who I am. How do you go about finding your registration code? I would have just reused my transaction e-mail, but I unfortunately I deleted it. Most online stores feature account profiles linked to E-mail, how do I go about finding how to re-register.
Thanks,
How do you login in as makemkv owner
Re: How do you login in as makemkv owner
You can start with Avangate support:
https://secure.avangate.com/support/?me ... te&lang=en
But if that doesn't get it done, try emailing: support@makemkv.com
Hope this helps.
Hope this helps.
In addition, check your email for a message from avangate.com; it will have your registration in it.
pmilleroly27
Thanks a lot. Be great if the makemkv.com had a link of some sort to Avangate. The download site and purchase site is a little disconnected. Anyway thanks for the help.
