Patti Cake$ no FUT MakeMKV 1.10.7
TsurG
Post by TsurG »
Patti Cake$ (Netflix) no FUT MakeMKV 1.10.7
Dump:
https://www.sendspace.com/file/5b0qkq
Re: Patti Cake$ no FUT MakeMKV 1.10.7
Posting the dump file on the forum is not nearly as quick as sending the link to svq@makemkv.com , since that goes directly to the author of the program.
unclecarmie
Post by unclecarmie »
FYI, I sent off my dump file to the email on Tuesday for this title.
TsurG
Post by TsurG »
Woodstock wrote:Posting the dump file on the forum is not nearly as quick as sending the link to svq@makemkv.com , since that goes directly to the author of the program.
Thanks, missed that.
johng
Post by johng »
What exactly does it mean when the "no FUT" error happens? Does than mean the decrypted output is no good and can't be used to rip the movie? Once the error is fixed do I need the original bluray disc to get "good" output, or can makemkv fix the original decrypted folder with the FUT error?
Grauhaar
Post by Grauhaar »
If MakeMKV signals "No FUT" created and you proceed with the copy, the content has some errors in it. The picture shows artefacts and so on. To fix this (an SVQ is created or upadeted) a complete new MakeMKV run by using the blu-ray is needed, it does not work with the created mkv file. This can also be a full copy (backup) of the Blu-ray on harddisc, but this backup must be done without decryption.
Good Luck :)
unclecarmie
It's working now, thank you!
