The Glass Castle correct playlist?
johng
#1 Post by johng » Wed Nov 08, 2017 12:02 am
anyone know the correct playlist for the glass castle?
Re: The Glass Castle correct playlist?
#2 Post by Woodstock » Wed Nov 08, 2017 1:08 am
Does MakeMKV not detect it?
johng
#3 Post by johng » Wed Nov 08, 2017 1:36 am
Woodstock wrote:Does MakeMKV not detect it?
How do I have MakeMKV detect it? Normally I just do a backup with MakeMKV and then use tsmuxer / ripbot264 to rip it.
#4 Post by Woodstock » Wed Nov 08, 2017 1:59 am
So, you don't know about the last year's worth of development where MakeMKV can use the (separately installed from java.com) Java Runtime Environment to detect fake play lists, and find (on most disks) the real play list, and move it to the top of the list?
If you have the JRE installed and you insert a BD from Lionsgate, you'll see a message about starting Java, and searching for the correct play list. If it does NOT find it, then you should see this topic: http://makemkv.com/forum2/viewtopic.php?f=8&t=14330
johng
#5 Post by johng » Wed Nov 08, 2017 2:08 am
yeah I have an old PC that I use for ripping and it's on an XP machine. It's the only machine I have a bluray drive installed in, so that's why I keep using it. I don't think I can put the new updates from the JRE on XP???
Woodstock wrote:So, you don't know about the last year's worth of development where MakeMKV can use the (separately installed from java.com) Java Runtime Environment to detect fake play lists, and find (on most disks) the real play list, and move it to the top of the list?
#6 Post by d00zah » Wed Nov 08, 2017 2:16 am
Java 7 does XP.
https://java.com/en/download/help/sysreq.xml
Will it suffice for MakeMKV's purposes?
#7 Post by Woodstock » Wed Nov 08, 2017 2:21 am
I believe it will. Java6 might even work.
johng
#8 Post by johng » Wed Nov 08, 2017 2:34 am
So I have Java 7 installed. It's in Program Files/Java/jre ....
but MakeMKV doesn't see it. I think I tried to fix this at some point in the past and nothing came of it. If I go into MakeMKV under prefrences/protection and then try to go to the Java directory under custom java location it won't see the Java directory for some reason?????
#9 Post by Woodstock » Wed Nov 08, 2017 3:41 pm
Have explorer search for "java.exe" on your system, note the directory.
Then, in MakeMKV, use the browse button on the "Custom Java executable location" to navigate to that directory, and click on java.exe.
If you can't browse to the directory, are you running MakeMKV as an administrator?
It SHOULD detect and use Java at that point, IF it is needed.... which it should be with this title from Lionsgate.
johng
#10 Post by johng » Wed Nov 08, 2017 4:53 pm
So this is the oddest thing. I only have one log in on this computer and it has admin privlages. If I click on the browse button under Protection "My Computer" is grayed out in the top left corner, and Files Of Type" is "all files (*)", and File Name: is blank. But no files are listed in the middle window like normal??
I was actually able to start typing in the exact location under File Name: and got to the point where it took the directory but nothing ever shows up in the middle box. Anyways it still doesn't look like it works. I post the output of what happens when I click on Open Disc in my next post.
johng
#11 Post by johng » Wed Nov 08, 2017 4:57 pm
MakeMKV v1.10.7 win(x86-release) started
Debug logging enabled, log will be saved as C:\Documents and Settings\jgiguere/MakeMKV_log_1.txt
Using Java runtime from C:/Program Files/Java/jre7/bin/java.exe
Title #00002.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.mpls has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00018.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.mpls has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.mpls has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00022.mpls has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00023.mpls has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00024.mpls has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00031.mpls has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00041.mpls has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00041.mpls(1) has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00042.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00043.mpls has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00044.mpls has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00045.mpls has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00079.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00080.mpls has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00081.mpls has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00082.mpls has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00084.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00084.mpls(1) has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00114.mpls has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00115.mpls has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00200.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00435.mpls was added as title #0
File 00450.mpls was added as title #1
Title 00451.mpls is equal to title 00450.mpls and was skipped
File 00451.mpls(1) was added as title #2
File 00515.mpls was added as title #3
Title 00700.mpls is equal to title 00450.mpls and was skipped
Title 00700.mpls(1) is equal to title 00451.mpls(1) and was skipped
File 00801.mpls was added as title #4
File 00802.mpls was added as title #5
Title #00803.mpls has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00804.mpls has length of 108 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00805.mpls was added as title #6
File 00806.mpls was added as title #7
File 00807.mpls was added as title #8
File 00808.mpls was added as title #9
Title #00809.mpls has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00810.mpls has length of 46 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00811.mpls has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00812.mpls has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00813.mpls has length of 102 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00814.mpls has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00815.mpls has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00816.mpls was added as title #10
Title #00817.mpls has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00818.mpls was added as title #11
Title #00819.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00820.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00821.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00822.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00823.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00824.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00825.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00826.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00827.mpls has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00828.mpls has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00829.mpls has length of 26 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00830.mpls has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00831.mpls has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00832.mpls has length of 39 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00833.mpls has length of 109 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00834.mpls has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00835.mpls has length of 38 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00836.mpls was added as title #12
Title #00837.mpls has length of 99 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00008.mpls was added as title #13
File 00009.mpls was added as title #14
File 00010.mpls was added as title #15
File 00013.mpls was added as title #16
File 00026.mpls was added as title #17
File 00032.mpls was added as title #18
File 00033.mpls was added as title #19
File 00034.mpls was added as title #20
File 00037.mpls was added as title #21
File 00039.mpls was added as title #22
File 00046.mpls was added as title #23
File 00053.mpls was added as title #24
File 00054.mpls was added as title #25
File 00056.mpls was added as title #26
File 00057.mpls was added as title #27
File 00058.mpls was added as title #28
File 00059.mpls was added as title #29
File 00060.mpls was added as title #30
File 00062.mpls was added as title #31
File 00066.mpls was added as title #32
File 00067.mpls was added as title #33
File 00070.mpls was added as title #34
File 00074.mpls was added as title #35
File 00075.mpls was added as title #36
File 00077.mpls was added as title #37
File 00078.mpls was added as title #38
File 00086.mpls was added as title #39
File 00087.mpls was added as title #40
File 00089.mpls was added as title #41
Title 00094.mpls is equal to title 00062.mpls and was skipped
File 00095.mpls was added as title #42
File 00097.mpls was added as title #43
File 00098.mpls was added as title #44
File 00100.mpls was added as title #45
File 00101.mpls was added as title #46
File 00102.mpls was added as title #47
File 00104.mpls was added as title #48
File 00108.mpls was added as title #49
Title 00109.mpls is equal to title 00032.mpls and was skipped
File 00112.mpls was added as title #50
File 00121.mpls was added as title #51
File 00122.mpls was added as title #52
File 00123.mpls was added as title #53
File 00124.mpls was added as title #54
File 00125.mpls was added as title #55
File 00127.mpls was added as title #56
File 00131.mpls was added as title #57
File 00132.mpls was added as title #58
File 00134.mpls was added as title #59
File 00142.mpls was added as title #60
File 00143.mpls was added as title #61
File 00144.mpls was added as title #62
File 00145.mpls was added as title #63
File 00149.mpls was added as title #64
File 00152.mpls was added as title #65
File 00153.mpls was added as title #66
File 00154.mpls was added as title #67
File 00156.mpls was added as title #68
File 00157.mpls was added as title #69
File 00158.mpls was added as title #70
File 00159.mpls was added as title #71
File 00162.mpls was added as title #72
File 00164.mpls was added as title #73
Title 00169.mpls is equal to title 00149.mpls and was skipped
File 00173.mpls was added as title #74
File 00175.mpls was added as title #75
File 00177.mpls was added as title #76
File 00178.mpls was added as title #77
File 00179.mpls was added as title #78
File 00182.mpls was added as title #79
File 00185.mpls was added as title #80
File 00186.mpls was added as title #81
File 00187.mpls was added as title #82
File 00188.mpls was added as title #83
File 00190.mpls was added as title #84
File 00193.mpls was added as title #85
File 00196.mpls was added as title #86
File 00199.mpls was added as title #87
File 00201.mpls was added as title #88
File 00203.mpls was added as title #89
File 00204.mpls was added as title #90
File 00206.mpls was added as title #91
File 00208.mpls was added as title #92
File 00209.mpls was added as title #93
Title 00210.mpls is equal to title 00054.mpls and was skipped
File 00215.mpls was added as title #94
File 00216.mpls was added as title #95
File 00217.mpls was added as title #96
File 00220.mpls was added as title #97
File 00222.mpls was added as title #98
File 00226.mpls was added as title #99
File 00230.mpls was added as title #100
File 00232.mpls was added as title #101
File 00233.mpls was added as title #102
File 00234.mpls was added as title #103
Title 00236.mpls is equal to title 00057.mpls and was skipped
Title 00237.mpls is equal to title 00067.mpls and was skipped
File 00241.mpls was added as title #104
File 00243.mpls was added as title #105
File 00244.mpls was added as title #106
File 00247.mpls was added as title #107
File 00252.mpls was added as title #108
File 00253.mpls was added as title #109
Title 00254.mpls is equal to title 00057.mpls and was skipped
File 00255.mpls was added as title #110
File 00256.mpls was added as title #111
File 00259.mpls was added as title #112
File 00260.mpls was added as title #113
Title 00261.mpls is equal to title 00241.mpls and was skipped
File 00262.mpls was added as title #114
Title 00263.mpls is equal to title 00196.mpls and was skipped
File 00264.mpls was added as title #115
File 00265.mpls was added as title #116
File 00266.mpls was added as title #117
File 00268.mpls was added as title #118
File 00271.mpls was added as title #119
File 00272.mpls was added as title #120
File 00273.mpls was added as title #121
File 00276.mpls was added as title #122
File 00277.mpls was added as title #123
File 00279.mpls was added as title #124
File 00282.mpls was added as title #125
Title 00284.mpls is equal to title 00108.mpls and was skipped
File 00286.mpls was added as title #126
Title 00288.mpls is equal to title 00201.mpls and was skipped
File 00290.mpls was added as title #127
File 00291.mpls was added as title #128
File 00293.mpls was added as title #129
Title 00294.mpls is equal to title 00247.mpls and was skipped
File 00295.mpls was added as title #130
File 00298.mpls was added as title #131
File 00302.mpls was added as title #132
File 00303.mpls was added as title #133
File 00308.mpls was added as title #134
File 00312.mpls was added as title #135
File 00315.mpls was added as title #136
File 00320.mpls was added as title #137
File 00323.mpls was added as title #138
File 00326.mpls was added as title #139
Title 00327.mpls is equal to title 00098.mpls and was skipped
File 00328.mpls was added as title #140
File 00330.mpls was added as title #141
Title 00333.mpls is equal to title 00132.mpls and was skipped
File 00334.mpls was added as title #142
File 00335.mpls was added as title #143
File 00336.mpls was added as title #144
Title 00337.mpls is equal to title 00286.mpls and was skipped
File 00338.mpls was added as title #145
File 00339.mpls was added as title #146
Title 00342.mpls is equal to title 00302.mpls and was skipped
Title 00344.mpls is equal to title 00153.mpls and was skipped
File 00345.mpls was added as title #147
File 00346.mpls was added as title #148
File 00347.mpls was added as title #149
File 00350.mpls was added as title #150
File 00356.mpls was added as title #151
Title 00357.mpls is equal to title 00175.mpls and was skipped
Title 00359.mpls is equal to title 00185.mpls and was skipped
Title 00360.mpls is equal to title 00199.mpls and was skipped
File 00363.mpls was added as title #152
File 00366.mpls was added as title #153
Title 00367.mpls is equal to title 00132.mpls and was skipped
File 00369.mpls was added as title #154
File 00373.mpls was added as title #155
Title 00376.mpls is equal to title 00123.mpls and was skipped
File 00378.mpls was added as title #156
File 00380.mpls was added as title #157
File 00383.mpls was added as title #158
File 00391.mpls was added as title #159
File 00392.mpls was added as title #160
File 00395.mpls was added as title #161
Title 00396.mpls is equal to title 00156.mpls and was skipped
Title 00404.mpls is equal to title 00123.mpls and was skipped
File 00405.mpls was added as title #162
File 00406.mpls was added as title #163
File 00408.mpls was added as title #164
File 00412.mpls was added as title #165
File 00417.mpls was added as title #166
File 00418.mpls was added as title #167
Title 00419.mpls is equal to title 00312.mpls and was skipped
File 00420.mpls was added as title #168
Title 00425.mpls is equal to title 00121.mpls and was skipped
Title 00426.mpls is equal to title 00312.mpls and was skipped
File 00427.mpls was added as title #169
File 00429.mpls was added as title #170
File 00430.mpls was added as title #171
Title 00431.mpls is equal to title 00326.mpls and was skipped
File 00433.mpls was added as title #172
File 00436.mpls was added as title #173
Title 00437.mpls is equal to title 00149.mpls and was skipped
File 00439.mpls was added as title #174
File 00444.mpls was added as title #175
File 00445.mpls was added as title #176
File 00446.mpls was added as title #177
File 00452.mpls was added as title #178
Title 00453.mpls is equal to title 00142.mpls and was skipped
Title 00454.mpls is equal to title 00182.mpls and was skipped
Title 00455.mpls is equal to title 00286.mpls and was skipped
Title 00458.mpls is equal to title 00264.mpls and was skipped
File 00460.mpls was added as title #179
File 00461.mpls was added as title #180
File 00462.mpls was added as title #181
File 00469.mpls was added as title #182
Title 00470.mpls is equal to title 00162.mpls and was skipped
Title 00472.mpls is equal to title 00054.mpls and was skipped
File 00477.mpls was added as title #183
File 00478.mpls was added as title #184
File 00479.mpls was added as title #185
File 00480.mpls was added as title #186
File 00481.mpls was added as title #187
File 00482.mpls was added as title #188
File 00485.mpls was added as title #189
Title 00490.mpls is equal to title 00271.mpls and was skipped
File 00491.mpls was added as title #190
File 00493.mpls was added as title #191
File 00497.mpls was added as title #192
File 00499.mpls was added as title #193
Title 00503.mpls is equal to title 00162.mpls and was skipped
File 00504.mpls was added as title #194
Title 00506.mpls is equal to title 00057.mpls and was skipped
File 00508.mpls was added as title #195
Title 00509.mpls is equal to title 00347.mpls and was skipped
File 00510.mpls was added as title #196
File 00512.mpls was added as title #197
File 00517.mpls was added as title #198
Title 00518.mpls is equal to title 00226.mpls and was skipped
File 00520.mpls was added as title #199
File 00529.mpls was added as title #200
File 00531.mpls was added as title #201
File 00534.mpls was added as title #202
Title 00536.mpls is equal to title 00131.mpls and was skipped
File 00538.mpls was added as title #203
File 00539.mpls was added as title #204
File 00543.mpls was added as title #205
File 00548.mpls was added as title #206
File 00550.mpls was added as title #207
File 00553.mpls was added as title #208
File 00554.mpls was added as title #209
File 00555.mpls was added as title #210
Title 00556.mpls is equal to title 00097.mpls and was skipped
File 00563.mpls was added as title #211
File 00564.mpls was added as title #212
Title 00568.mpls is equal to title 00499.mpls and was skipped
File 00570.mpls was added as title #213
File 00571.mpls was added as title #214
Title 00575.mpls is equal to title 00320.mpls and was skipped
File 00584.mpls was added as title #215
File 00589.mpls was added as title #216
File 00591.mpls was added as title #217
File 00593.mpls was added as title #218
File 00594.mpls was added as title #219
File 00596.mpls was added as title #220
Title 00597.mpls is equal to title 00298.mpls and was skipped
File 00598.mpls was added as title #221
Title 00604.mpls is equal to title 00008.mpls and was skipped
File 00607.mpls was added as title #222
Title 00610.mpls is equal to title 00162.mpls and was skipped
File 00612.mpls was added as title #223
Title 00615.mpls is equal to title 00499.mpls and was skipped
Title 00621.mpls is equal to title 00122.mpls and was skipped
File 00625.mpls was added as title #224
Title 00626.mpls is equal to title 00131.mpls and was skipped
File 00630.mpls was added as title #225
Title 00632.mpls is equal to title 00247.mpls and was skipped
File 00633.mpls was added as title #226
File 00636.mpls was added as title #227
File 00637.mpls was added as title #228
File 00639.mpls was added as title #229
File 00640.mpls was added as title #230
File 00642.mpls was added as title #231
Title 00646.mpls is equal to title 00121.mpls and was skipped
File 00647.mpls was added as title #232
File 00650.mpls was added as title #233
Title 00654.mpls is equal to title 00286.mpls and was skipped
File 00655.mpls was added as title #234
Title 00657.mpls is equal to title 00078.mpls and was skipped
Title 00662.mpls is equal to title 00295.mpls and was skipped
File 00667.mpls was added as title #235
File 00669.mpls was added as title #236
File 00671.mpls was added as title #237
Title 00674.mpls is equal to title 00008.mpls and was skipped
Title 00675.mpls is equal to title 00132.mpls and was skipped
Title 00678.mpls is equal to title 00121.mpls and was skipped
File 00680.mpls was added as title #238
Title 00682.mpls is equal to title 00067.mpls and was skipped
File 00683.mpls was added as title #239
File 00685.mpls was added as title #240
File 00686.mpls was added as title #241
Title 00689.mpls is equal to title 00469.mpls and was skipped
Title 00690.mpls is equal to title 00469.mpls and was skipped
File 00691.mpls was added as title #242
File 00696.mpls was added as title #243
Title 00697.mpls is equal to title 00241.mpls and was skipped
File 00698.mpls was added as title #244
File 00699.mpls was added as title #245
File 00701.mpls was added as title #246
Title 00703.mpls is equal to title 00199.mpls and was skipped
File 00709.mpls was added as title #247
File 00711.mpls was added as title #248
File 00713.mpls was added as title #249
Title 00714.mpls is equal to title 00175.mpls and was skipped
File 00716.mpls was added as title #250
File 00718.mpls was added as title #251
File 00727.mpls was added as title #252
File 00729.mpls was added as title #253
File 00731.mpls was added as title #254
File 00732.mpls was added as title #255
Title 00733.mpls is equal to title 00062.mpls and was skipped
Title 00736.mpls is equal to title 00520.mpls and was skipped
File 00737.mpls was added as title #256
File 00739.mpls was added as title #257
File 00741.mpls was added as title #258
File 00742.mpls was added as title #259
Title 00743.mpls is equal to title 00485.mpls and was skipped
File 00744.mpls was added as title #260
Title 00745.mpls is equal to title 00177.mpls and was skipped
File 00746.mpls was added as title #261
File 00748.mpls was added as title #262
File 00749.mpls was added as title #263
File 00759.mpls was added as title #264
File 00760.mpls was added as title #265
Title 00763.mpls is equal to title 00208.mpls and was skipped
Title 00764.mpls is equal to title 00746.mpls and was skipped
File 00766.mpls was added as title #266
Title 00768.mpls is equal to title 00008.mpls and was skipped
Title 00769.mpls is equal to title 00298.mpls and was skipped
File 00770.mpls was added as title #267
File 00771.mpls was added as title #268
File 00772.mpls was added as title #269
File 00773.mpls was added as title #270
File 00775.mpls was added as title #271
File 00776.mpls was added as title #272
File 00777.mpls was added as title #273
File 00781.mpls was added as title #274
File 00784.mpls was added as title #275
Title 00786.mpls is equal to title 00298.mpls and was skipped
Title 00790.mpls is equal to title 00196.mpls and was skipped
File 00795.mpls was added as title #276
Title 00799.mpls is equal to title 00636.mpls and was skipped
Title 00839.mpls is equal to title 00326.mpls and was skipped
File 00840.mpls was added as title #277
File 00843.mpls was added as title #278
File 00844.mpls was added as title #279
File 00852.mpls was added as title #280
Title 00853.mpls is equal to title 00059.mpls and was skipped
Title 00856.mpls is equal to title 00142.mpls and was skipped
Title 00861.mpls is equal to title 00216.mpls and was skipped
File 00866.mpls was added as title #281
Title 00867.mpls is equal to title 00153.mpls and was skipped
Title 00868.mpls is equal to title 00199.mpls and was skipped
File 00874.mpls was added as title #282
File 00875.mpls was added as title #283
File 00876.mpls was added as title #284
File 00877.mpls was added as title #285
File 00878.mpls was added as title #286
Title 00879.mpls is equal to title 00008.mpls and was skipped
File 00881.mpls was added as title #287
File 00884.mpls was added as title #288
File 00886.mpls was added as title #289
File 00888.mpls was added as title #290
File 00889.mpls was added as title #291
File 00894.mpls was added as title #292
Title 00895.mpls is equal to title 00057.mpls and was skipped
File 00898.mpls was added as title #293
Title 00905.mpls is equal to title 00131.mpls and was skipped
File 00912.mpls was added as title #294
File 00913.mpls was added as title #295
Title 00914.mpls is equal to title 00345.mpls and was skipped
File 00917.mpls was added as title #296
File 00920.mpls was added as title #297
Title 00921.mpls is equal to title 00175.mpls and was skipped
Title 00925.mpls is equal to title 00247.mpls and was skipped
Title 00926.mpls is equal to title 00131.mpls and was skipped
Title 00931.mpls is equal to title 00510.mpls and was skipped
Title 00932.mpls is equal to title 00727.mpls and was skipped
Title 00936.mpls is equal to title 00510.mpls and was skipped
File 00939.mpls was added as title #298
Title 00941.mpls is equal to title 00199.mpls and was skipped
Title 00943.mpls is equal to title 00529.mpls and was skipped
File 00946.mpls was added as title #299
File 00947.mpls was added as title #300
File 00948.mpls was added as title #301
Title 00949.mpls is equal to title 00033.mpls and was skipped
File 00951.mpls was added as title #302
File 00959.mpls was added as title #303
Title 00960.mpls is equal to title 00320.mpls and was skipped
File 00961.mpls was added as title #304
File 00962.mpls was added as title #305
File 00963.mpls was added as title #306
Title 00965.mpls is equal to title 00510.mpls and was skipped
File 00968.mpls was added as title #307
Title 00970.mpls is equal to title 00108.mpls and was skipped
Title 00972.mpls is equal to title 00164.mpls and was skipped
File 00978.mpls was added as title #308
File 00982.mpls was added as title #309
File 00983.mpls was added as title #310
File 00984.mpls was added as title #311
File 00985.mpls was added as title #312
File 00987.mpls was added as title #313
Title 00988.mpls is equal to title 00108.mpls and was skipped
Title #00002.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 22 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00022.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00023.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00024.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00025.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00272.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00273.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00274.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00275.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
johng
#12 Post by johng » Wed Nov 08, 2017 4:58 pm
Is there something in that output that is supposed to tell me the correct playlist?
#13 Post by d00zah » Wed Nov 08, 2017 5:18 pm
Java was recognized:
so IF it worked, the top entry in the title list SHOULD be labeled "Main Feature", otherwise, submit info as detailed in the link Woodstock posted above.
johng
#14 Post by johng » Wed Nov 08, 2017 6:03 pm
It's asking for a compressed version of the STREAM and BDSVM folders, but I can't find a BDSVM folder? Is that always generated? I have a BDJO folder??
#15 Post by Woodstock » Wed Nov 08, 2017 6:23 pm
Are you working from the disk itself, and image of the disk, or a backup of it?
