New here but using MakeMKV for a long time. I usually only save the main feature from a DVD or Blu-ray. Some of these have menu structures with several dozen items, which I then go un-check manually one at a time. It would be great to have a check/uncheck all for the list of checkboxes so people who are just pulling the main movie or a few episodes can skip out of all of the trailers, FBI warnings, etc.
I'd like to ask for this feature, please. This is such a fantastic product.
Feature Request - Checkboxes
Re: Feature Request - Checkboxes
MakeMKV has 2 features which I THINK address this request.
Under Options > Video, the user can set a minimum title length. Setting this to '1800' gets me only the main feature in most cases.
Right-clicking on an item in the left-hand list of titles shows a context menu which allows the user to:
- Toggle item
- Select all
- Unselect all
Either of these ought to make your life easier?
- Toggle item
- Select all
- Unselect all
CountryKnight
Oh sweet! The right-click toggle fixes it all. Would be a TAD easier if there were a checkbox up at the top (like GMail) though.
